Asus x453ma not charging
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hello friends, I hope someone will give up a moment to help me solve the problem on the asu x453ma motherboard with the condition that it can't charge when it is charged, and this is the result of measuring the bq735 ic voltage
    acin : 19v (pin1)
    acdrv: 4.02v (pin4) unstable
    sda: 2.5v(pin8)
    regn: 6.2v(pin16)
    vcc: 19v(pin20)
    I hope someone can help me or give directions to solve this problem, thanks.
  • mon2
    • Dec 2019
    • 14721
    Re: Asus x453ma not charging
    1) is the battery a known good battery ? Often, the battery is the root cause. Asus is horrible for batteries. Our son's laptop (i7 Quad core - ROG751 I believe) purchased new had a dead battery after just 12 months.
    How old is this battery ? Have you tested a fresh & new battery ?
    2) Post all of the voltages measured on the charger IC (BQ735).
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      1.thank you friend for the time you took to help me, the condition of the battery I used was a new battery, and I didn't find a short circuit in the charging block.
      I thought that the bq735 ic was broken, because sometimes the VIN voltage from the adapter drops to 4.05v, and to get 19v back, you have to unplug and re-plug the adapter connection and the laptop can be turned on normally but can't charge when charging.
      • Yosua
        • Jun 2021
        • 221
        • Indonesia
        OK, I'll re-measure all the pins later. thank you
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          acin : 19v (pin1)
          sda: 2.5v(pin8)
          regn: 6.2v(pin16)
          vcc: 19v(pin20)
          ACDRV voltage should be 25V approx. SDA should be stable 3.3V and not 2.5V. Check whether you have 19V at CMSRC pin of charging IC. ACDET pin voltage??DC-In mosfets checked??
          • Yosua
            • Jun 2021
            • 221
            • Indonesia
            in the dc mosfet there is a voltage of 19v at the input and output bro..
            But on the 1st and 2nd mosfet gates it only outputs 19v.
            because I understand that the N CHANEL mosfet on the gate must output a greater voltage from the source and drain right?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes, dc-in mosfet gate should be 25V approx and its controlled by ACDRV pin of charger IC. Check whether dc-in mosfet is shorted/leaky and presence of 19V at CMSRC pin of charging IC as mentioned earlier.
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                thank you for helping me so far, the CMSRC pin on the BQ735 ic is normal voltage and outputs 19v, only ACDRV is not normal, and the avo meter only flashes when it displays 19v
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  Does it flash because it is going into protection Mode?
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    Thanks guys for the time you took to help me, does that mean there's a short-circuit problem on this line?
                    because my measurements did not find a grounded component on this line.
                    please help me for this case
                    • mon2
                      • Dec 2019
                      • 14721
                      Remove all power.
                      Meter in resistance mode (200 ohms).
                      Check and post the resistance of each of the front 2 mosfets.
                      1) source and drain
                      2) source and gate
                      3) gate and drain
                      Your dc adapter should not be dropping down the voltage like you have observed unless there is a fault with these mosfets.
                      • Yosua
                        • Jun 2021
                        • 221
                        • Indonesia
                        Remove all power.
                        1) source and drain
                        2) source and gate
                        3) gate and drain
                        thank you very much my friend for taking your time for a minute, does that mean there is a change in the resistance of the two dc mosfet?
                        OK, I'll try to measure it again later.
                        on the acdrv line also passes through a resistor, do I need to measure it too?
                        because I also read the datasheet of BQ24735 This
                        • Bonzas
                          • 474
                          • Indonesia
                          Just stupid question from me ? Not charging, battery status on OS.
                          1. Plugin, not charging ?
                          2. Plugin, charging but battery won't fill ?
                          3. Battery not detected ?
                          I found some asus battery, especially compatible battery isn't not good. I must try 3- 4 battery when buy new battery for testing laptop that not charging issue.
                          There's some resistor on acdrv line ( divider ) that can cause dropping voltages. Does your laptop can turn on with battery only ?
                          • Yosua
                            • Jun 2021
                            • 221
                            • Indonesia
                            Iya bang , kalo pake batre aja bisa koq (plugin,charging) tapi gak terisi bang
                            • mon2
                              • Dec 2019
                              • 14721
                              Measure and post the resistance of the pins of each front side mosfet.
                              You will be measuring them directly at the pins of the part as requested above.
                              Post pics of the mosfet with their part markings if you need any help.
                              This test should be done with no power. We are checking to see if the mosfet is shorted.
                              See this article - the table offers a good summary here:
                              http://electronicsbeliever.com/how-t...-is-defective/
                              • Bonzas
                                • 474
                                • Indonesia
                                wis nyoba baterai liyane cak ?
                                coba solder/panasi ic kbc ne, dicas posisi lepi mati gelem ngisi gak ?
                                Check again vcc line, you said before that vcc pin sometimes drop. maybe some capasitor filter ( 19v ) are bad, it can make unstable on acdrv that needed to trigger on battery fet
                                • Yosua
                                  • Jun 2021
                                  • 221
                                  • Indonesia
                                  I've replaced 2 fet dc in and the result is still the same, I'm getting confused, here I measure again after replacing the fet: BQ735 IC CHARGER
                                  PIN1(ACN) = 19.21V
                                  PIN2(ACP) = 19.23V
                                  PIN3 (CMSRC) = 19.04V
                                  PIN4 (ACDRV) = 19.03V(flashes on avometer)
                                  PIN5(ACOK) = 1.65V
                                  PIN6 (ACDET) = 2.84V
                                  PIN7(iOUT) = 0.04V
                                  PIN8(SDA) = 0.01V
                                  PIN9(SCL) = 0.01V
                                  PIN10 (ILIM) = 0.19V
                                  PIN11 (BATDRV) = 2.81V
                                  PIN12(SRN) = 2.80V
                                  PIN13(SRP) = 2.82V
                                  PIN14 (GND)
                                  PIN15(LODRV) = 0V
                                  PIN16(REGN) = 6.10V
                                  PIN17(BTST) = 5.89V
                                  PIN18 (HIDRV) = 2.95V
                                  PIN19 (PHASE) = 2.93V
                                  PIN20(VCC) = 19.14V
                                  • Yosua
                                    • Jun 2021
                                    • 221
                                    • Indonesia
                                    Mari mas tapi nggae batre lio pancet, gak masalah ta manasi kbc?
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      English only on this forum.
                                      • Bonzas
                                        • 474
                                        • Indonesia
                                        no, or you can ACP bc chip
                                        Pardon me sir
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • johnbeton
                                          Asus X415EA not charging battery
                                          by johnbeton
                                          I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                                          So far I measured all the pins on the bq24780s controller with the following result:
                                          1. ACN = 0.0V
                                          2. ACP = 19.02V
                                          3. CMSRC = 18.5V
                                          4. ACDRV = 23.9V
                                          5. ACOK = 5.9V
                                          6. ACDET = 2.57V
                                          7. IADP = 0.17V
                                          8. IDCHG = 0V
                                          9. PMON = ?
                                          10. PROCHOT = 5.05V
                                          11. SDA = 3.3V
                                          12. SCL = 3.3V
                                          13. CMPIN = 0.47V
                                          14. CMPOUT = 6.0V
                                          15. BATPRES = 0.0V
                                          16....
                                          05-19-2025, 04:05 AM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • lazenes
                                          ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
                                          by lazenes
                                          The device is not charging with the 19V 180W DC charger. If the battery is full, the laptop powers on normally. I can charge it via USB Type-C, but it’s very slow. I checked the schematics but couldn’t find a solution. I even replaced the BQ24800 battery charging IC, but the issue remains the same. I suspect a MOSFET or a fuse that I might be overlooking is preventing it from charging with the adapter. Has anyone experienced a similar fault before or has any advice?...
                                          09-18-2025, 01:48 PM
                                        • thomasmagic
                                          not charging asus g531gw 1.6
                                          by thomasmagic
                                          hello,
                                          if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
                                          i have found short on C3907 (PVDD_AMP) and remove it
                                          Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
                                          It's not 1st time when i remove short after the battery is not detect
                                          On mybook i know we can make jumper beetween two lines for recognised this one
                                          do you have solution for pc and actually this mainboard? Thanks for your help ...
                                          06-19-2025, 12:54 PM
