Asus x453ma not charging
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    #81
    Re: Asus x453ma not charging
    Originally posted by mon2
    Please review my last message.
    Summary:
    1) replacing the resistors is a good idea but if 0.77V = should be ok if holding steady
    2) consider to replace the charger IC since the HIDRV & LODRV voltages are too low to enable PQ8804 & PR8805 mosfets
    3) not a bad idea to order replacement mosfets for PQ8804 & PQ8805 - just in case.
    okay I'll remember your message bro thanks for helping so far, I got a lot of knowledge here
    does this mean you won't direct me anymore?
    hehehe just making sure :v
    if I may ask, is the PQ8805 really worth 0v under normal conditions?
    • mon2
      • 14721
      I think the issue is within the few parts. Based on the review so far, the charger IC really should be driving the gate pins at higher voltages.
      Proceed to replace the charger IC and see if the results improve.
      If not, replace the mosfets. Perhaps others will have some other input on the topic but believe it is down to these parts.
      No issue to post and if I can help, will do so.
      Truth is that we are both learning. Personally do not have access to this logic board so learning as we go.
      • Yosua
        • Jun 2021
        • 221
        • Indonesia
        #83
        you are right bro... i will do what you directed... , i will try to find what i need on another motherboard first, thanks
        • Yosua
          • Jun 2021
          • 221
          • Indonesia
          #84
          thank you for your guidance so far, my friend, now the asus x453ma that I'm working on is in order and working properly, it turns out that this BQ735 is no longer feasible and I exchanged it for a new one, thank you for guiding me too to work on the ACOK problem which also caused problems on the block this charger, if it weren't for you guys my problem with this motherboard would have not been solved
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • johnbeton
            Asus X415EA not charging battery
            by johnbeton
            I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
            So far I measured all the pins on the bq24780s controller with the following result:
            1. ACN = 0.0V
            2. ACP = 19.02V
            3. CMSRC = 18.5V
            4. ACDRV = 23.9V
            5. ACOK = 5.9V
            6. ACDET = 2.57V
            7. IADP = 0.17V
            8. IDCHG = 0V
            9. PMON = ?
            10. PROCHOT = 5.05V
            11. SDA = 3.3V
            12. SCL = 3.3V
            13. CMPIN = 0.47V
            14. CMPOUT = 6.0V
            15. BATPRES = 0.0V
            16....
            05-19-2025, 04:05 AM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • lazenes
            ASUS TUF Dash Motherboard FX516 REV 6.0 Model Device Not Charging
            by lazenes
            The device is not charging with the 19V 180W DC charger. If the battery is full, the laptop powers on normally. I can charge it via USB Type-C, but it’s very slow. I checked the schematics but couldn’t find a solution. I even replaced the BQ24800 battery charging IC, but the issue remains the same. I suspect a MOSFET or a fuse that I might be overlooking is preventing it from charging with the adapter. Has anyone experienced a similar fault before or has any advice?...
            09-18-2025, 01:48 PM
          • thomasmagic
            not charging asus g531gw 1.6
            by thomasmagic
            hello,
            if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
            i have found short on C3907 (PVDD_AMP) and remove it
            Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
            It's not 1st time when i remove short after the battery is not detect
            On mybook i know we can make jumper beetween two lines for recognised this one
            do you have solution for pc and actually this mainboard? Thanks for your help ...
            06-19-2025, 12:54 PM
