Asus F712J
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Asus F712J
    Hi, Asus F712J, board X512JA Rev2.0, no power, I replace BQ24780S and few mosfet and first resistor 10mOhm in power line from power jack. Laptop power on with screen windows ok, system win10 ok, but I can't turn off, battery charging the orange LED is constantly on and there are 3V and 5V voltage and PCH power supply I need schematic, board view and bios dump or good solution.
    Sorry my bad english.
    Regards.
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Re: Asus F712J
    https://www.badcaps.net/forum/attach...1&d=1636052187
    can anyone help identify this chip ?
    after tur on - S0 - 1,80V
    after turn off - S? - 1,10V
    power source pch ?
    after turn off I suppose the board doesn't reach S5 state, battery powered without charger, maintains 3 and 5V and 1.8V voltage, led charging orange if battery charging, white after charge. still white after off without charger.
    • mon2
      • Dec 2019
      • 14672
      Re: Asus F712J
      Attached.
      • warsztat
        • Feb 2017
        • 190
        • Polska
        Re: Asus F712J
        thank you
        (vid1 == 0 && vid0 == 1)
        { vout = 1,10V; }
        I still don't have a schematic, ic look good , Vout is 1,10V .
        The output voltage is 1.10V because this is how the "vid" inputs are controlled.
        Maybe I will try to reprogram kbc, anyone has a file for kbc for this laptop or extract from bios ?
        • warsztat
          • Feb 2017
          • 190
          • Polska
          Re: Asus F712J
          schematic and boardview not available? I need to identify the keyboard pins for the programmer (RT809F)
            • 21917
            Re: Asus F712J
            Regards.
            Laptop Schematic requests - https://www.badcaps.net/forum/forumdisplay.php?f=41
            Laptop bios requests - https://www.badcaps.net/forum/forumdisplay.php?f=40
            No schematic,boardview or repair guide available yet .
            • warsztat
              • Feb 2017
              • 190
              • Polska
              Re: Asus F712J
              Pin 5 BQ24780S ACOK still H logic level. My BQ is broken, I replace another BQ from broken board well all ok. System turn on and off, is ok. Now I testing.
              I am old and blind.
              Thanks all.
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • ShadowAi
                ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                by ShadowAi
                Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                03-15-2024, 10:46 AM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
