a1932 820-011521-a
  • alfredodinolfo
    • 128
    • N/A
    a1932 820-011521-a
    hi,
    this macbook is in recovery mode.
    If I try to restore whit apple configurator 2 show me error 4010 when installing system.
    Can You help me?
  • mon2
    • Dec 2019
    • 14664
    Re: a1932 820-011521-a
    https://discussions.apple.com/thread...e.com%2Fitunes.
    • alfredodinolfo
      • 128
      • N/A
      Thank you but this is for iphone.
      • mon2
        • Dec 2019
        • 14664
        The error code and issue appears to be the same across the Apple products.
        From the posts, it means that you do not have an internet connection to the Apple servers. Perhaps a local firewall or similar issue ?
        That is a communications error. If you have a firewall or antivirus try restarting your computer, then temporarily disable them. You should also verify that you have the latest version of iTunes if your computer runs Windows. You can get it from https://apple.com/itunes.
        • alfredodinolfo
          • 128
          • N/A
          I don't know. I try Apple Configurator 2 on macbook pro 2016 T1 to recovery macbook air 2020 T2. Is this wrong?
          • dbuergi
            Water damaged MacBook Air A1932 AmrestoreErrorDomin Error-9 trying to restore with configurator
            by dbuergi
            this Macbook was stuck at 5v and didn't start because of some water damage. I was able to clean everything and the board started. So i put everything back together and the Macbook seems to boot with 20v, 1,4A and 29W. So i decided a DFU recovery. At 50% of the system repair i get the error massage from the title. Display stays black and no Apple logo. Both repair and recovery don't work.
            Is there anything i can do?
            11-19-2024, 09:27 AM
          • kjchatman
            820-01949 charges the battery but doesn't complete the restore in apple configurator
            by kjchatman
            this one was powering up but no display and i later found a cap that was shorted to ground on 1v1_s3. but before i found that short i reflowed some stuff now i can't get it to power up anymore but the battery will charge
            03-22-2024, 02:30 PM
          • tech_guru
            Macbook Pro 2019 A2141 NAND Shorted
            by tech_guru
            Hello. If you could please help me understand what I am doing wrong...
            This model, Macbook Pro 2019 16" A2141, 512GB, EMC 3347, with T2 Security Chip, had 4 NAND Chips shorted in 1 wing (U9100, U9200, U9300, U9400) and it has 1 more in the 2nd wing (U8600) BUT NOT shorted. All chips are TSB4227 TOSHIBA-KIOXIA SN4192TWNA12014 BGA110 128GB. I got 4 new nand chips for 1 wing and programmed them by specific position of course with JCID P13 programmer.
            I also replaced the tps power ic for the ssd.
            Now all rails come up, including the ssd rails 0.9v, 1.8v, 2.5v....
            08-28-2025, 08:04 AM
          • nikolayu
            MacBook Air A1932 internet recovery loop
            by nikolayu
            I have A1932 that is going to internet recovery every time.
            i tried nvram and smc reset but it looks that MacBook is not reacting to that.
            i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
            keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
            also won’t open option to boot from usb device.
            and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
            07-22-2025, 02:55 AM
          • madjid911
            Macbook air A1932 no power
            by madjid911
            Hi, I have a MacBook that won't start at all, no sign of life, no display but the trackpad reacts., it's the A1932 820-01521-02 model with T2 chip, I tried to flash it in dfu mode it's detected on my mac, but it gives error 9 when I want to restart the chip, and error 4010 and 75 when I want to restore it, yet the icloud was removed on the icloud site the mac was deleted, anyway it was a little oxidized slightly so I cleaned everything, now I took all the voltages here they are:
            pp3V3_UPC_XB_LDO : 3V27
            PPVBAT_G3H_FUSE : 12V6 UNSTABLE FALLS to 0V187 every 4 seconds
            PPDCIN_G3H_CHGR_AMON...
            07-18-2025, 08:48 AM
