Macbook air A1932 no power
  • madjid911
    • 412
    • France
    Hi, I have a MacBook that won't start at all, no sign of life, no display but the trackpad reacts., it's the A1932 820-01521-02 model with T2 chip, I tried to flash it in dfu mode it's detected on my mac, but it gives error 9 when I want to restart the chip, and error 4010 and 75 when I want to restore it, yet the icloud was removed on the icloud site the mac was deleted, anyway it was a little oxidized slightly so I cleaned everything, now I took all the voltages here they are:
    pp3V3_UPC_XB_LDO : 3V27
    PPVBAT_G3H_FUSE : 12V6 UNSTABLE FALLS to 0V187 every 4 seconds
    PPDCIN_G3H_CHGR_AMON : 19V78
    PPBUS_G3H : 12V62 stable
    PP3V3_G3H_RTC : 3V3
    PP1V8_AWAKE : 1V8
    PP3V3_AWAKE : 3V3
    PP1V1_SLPS2R : 1V1
    PP1V8_G3S : 1V8
    PP5V_G3S : 5V
    PP3V3_S5 : 0V 0,6 MOHMS no short
    PP3V3_G3H : 3V3
    LDO_RTC : 1V5
    If anyone can help me please as I am not an expert in troubleshooting. The unstable 12V6 on the fuse makes me think that the t2 chip has a problem and cycles all the time, I tried to reset the SMC and flash the T2 chip but no result and impossible to flash the chip it gives me an error all the time
  • mon2
    • 14723
    Suggest to implant a fresh image of the T2 firmware onto the T2 rom device. The dumps should be available in the ROM / DUMP sub-forum of this website. Backup the original as a CYA (cover your a*s).
    • madjid911
      • 412
      • France
      what looks like the SPI chip on the board is U4730 and U4770, which would be the SPI chip?
      Can I take the chip from a donor motherboard? Because I don't have the tool to read this small chip.
      • mon2
        • 14723
        The SOC chip for the T2 is the U4770 on your board. You are correct, it is a real bastard of a part that is not even available in North America and has months of lead time even if you are ok with purchasing 2k++ qty on tape & reel. Everyone and their mother sells it on Aliexpress. We now have all of the tools to experiment with this nasty SMD part - still trying to resurrect a dead iMAC that has this part.
        Master Liu noted that it is ok to use T2 SOC from another board to fix a non-working T2 board (any model). Concluding that the DFU process does exactly this. So if you have another T2 board -> locate the local SOC flash device and transplant on to your dead board. Curious to hear of your progress, either way. Be sure to watch the pin #1 orientation of these devices.
        • madjid911
          • 412
          • France
          I just tried twice taking the chip two donor motherboard, the result is the same error 4010
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Loki_Fido
            Requesting help identifying chip in Macbook Pro A2485
            by Loki_Fido
            Hi ya folks,
            I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
            It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
            I replaced it and the SSD are fine. No more shorts.
            But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
            But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
            Chip marking...
            08-07-2025, 10:17 PM
          • SSBDADC234
            MacBook Pro 14". The screen DP chip failed.
            by SSBDADC234
            When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
            However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
            Testing the chip pins with a multimeter revealed a short circuit inside the chip.
            Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
            04-19-2024, 08:51 PM
          • PACh
            Original Data for T2 ROM Chip Macbook Air A1932 820-01521-A
            by PACh
            Hello, im looking for the Original Data for the T2 ROM Chip for a Macbook Air A1932 820-01521-A
            The one I saved gives me an error in the verify phase, when I install it back the macbook stays in DFU mode…
            Thanxs in advance
            09-08-2022, 01:29 PM
