Left capacitive button issue on Tab A7 (2016)
  • paparazzo79
    • Dec 2018
    • 298
    • Bosnia
    I purchased used tablet and ofc what can you expect from used stuff except issues.
    Left capacitive button sometimes works sometimes ain't.
    What usually causes this issue and is it repairable?
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
  • dfear
    HP 14-bf054sa - weird power button issue
    by dfear
    - forum postHP 14-bf054sa
    LA-F301P Rev 1.0
    This laptop came in with a number of minor issues (Screen with black bar and battery that needs replacing). The laptop also had issues relating to salt (water/air) corrosion, having been used near the ocean.
    The HDMI port, 2x usb ports and the SD card reader all needed replacement as they had been affected by salty air and only work intermittently. The HDMI port, 2x usb ports and the SD card reader have been replaced and have been checked for (obvious) shorts.
    The laptop now fails to turn on (normally)....
    09-24-2021, 09:33 AM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
  • H1ghl4nd3r
    Synology DS415+ power button response issue
    by H1ghl4nd3r
    Had another issue with turning the machine on (1 in 5 it will turn on) so had to strip it down again thinking the power on button is damaged but it is in good condition, then had a look at the motherboard button and it looks like a part of it has snapped off see attached pics.
    Can anyone recommend a replacement for the motherboard, it has 8 pins and would prefer a blue led if possible.
    The closest I have found is part number: PB6156RSL-4-102 (Blue led) PB6156RSL-3-102 (green) but agin struggling to find that part in the uk...
    06-03-2023, 08:15 AM
