A1707 2017 LCD Dark after Liquid
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    i have a MacBook Pro 15 "2017 820-00281 and everything works. But the display remains dark! I have corrosion on pin 43 and pin 1 of the LVDS connector and that's why I replaced the U9850 and the LVDS cable! But the display remains dark! I have the display tested on the other MacBook, the display is 100% intact. I also installed the OSX on the external monitor. I have just measured F8400. Fuse is ok!
    A help would be great ;-)
  • mon2
    • Dec 2019
    • 14684
    Re: A1707 2017 LCD Dark after Liquid
    Check the backlight voltage for the display.
    Voltage reading?
    Try pram reset as well.
    • Strolch
      • Nov 2017
      • 245
      • Deutschland
      Hi, how can i check it? Ore where?
      • mon2
        • Dec 2019
        • 14684
        See attached.
        Any yellow marked location = backlight voltage.
        Just be very careful with the meter probes.
        Meter in DC voltage setting (200 volts is good as the LCD backlight should be 25V or maybe higher if working correctly).
        Red meter to any of the yellow highlighted points - they are all connected together on the circuit board so any point will do.
        Black lead of the meter to any ground point = metal shield is ok.
        Also, when the laptop is on, shine a flashlight along the front face of the display - can you see any of the usual boot logo graphics / login screen, etc. ?
        • piernov
          • Jan 2016
          • 4439
          • France
          As it has been said many times, no point in troubleshooting backlight if there is no image.
          Hard to see image on these LCD so at the very least LCD power rail should be measured to see if LCD is detected and powered.
          • Strolch
            • Nov 2017
            • 245
            • Deutschland
            @when the laptop is on, shine a flashlight along the front face of the display.
            Hi, at the front is nothing to see! Thats why i replaced the U9850.
            I just took measurements! I have 0 volts at the points! I have 11.7V on the fuse nearby.
            • Strolch
              • Nov 2017
              • 245
              • Deutschland
              I Have 0 Volts at the C84.... +CC78 Points.
              • mon2
                • Dec 2019
                • 14684
                Can you check & post the cap location where you are measuring this voltage? Unable to locate C84.
                • Strolch
                  • Nov 2017
                  • 245
                  • Deutschland
                  i measured all the points you said Like on the picture. I have 0 volts D8410 also 0 volts
                  • mon2
                    • Dec 2019
                    • 14684
                    Check the PP5V_S0SW_LCD on J8500.
                    Post the voltages for 1, 2 and 3 of the attached.
                    • Strolch
                      • Nov 2017
                      • 245
                      • Deutschland
                      Hi, i have at the U8500 Pin 1 and Pin 5 5Volts! And at R8515 3,7Volts!
                      • mon2
                        • Dec 2019
                        • 14684
                        Confirm the same voltages and the other backlight voltage is reaching J8500.
                        • mon2
                          • Dec 2019
                          • 14684
                          Measure & post the voltage on R9855. Need to confirm if the MUX (multiplexer) that shoots out the video over the eDP port onto J8500 is enabled or not.
                          See attached.
                          If the MUX is enabled with a logic '1' (HIGH) then there is a possibility that the MUX itself is defective and not passing through the signals onto the display panel.
                          This is assuming the display panel is a known good display and the relevant voltages are present. Then it is down the video signals that are sent over the eDP lines but this MUX is between the GPU and this LCD connector.
                          The MUX resides @ U9850 and appears that there is a low cost TI equivalent for this device.
                          P/N HD3SS212
                          * datasheet is attached
                          • Strolch
                            • Nov 2017
                            • 245
                            • Deutschland
                            yes the Pin 45 has 5Volts
                            • mon2
                              • Dec 2019
                              • 14684
                              Also share the voltage reading for the backlight @ D8410.
                              Can you see any backlight on your display ?
                              • Strolch
                                • Nov 2017
                                • 245
                                • Deutschland
                                at R9855 i have 3,3Volts on the Pin1 and pin 2
                                • Strolch
                                  • Nov 2017
                                  • 245
                                  • Deutschland
                                  at the first post I write that I replace the U9850
                                  • mon2
                                    • Dec 2019
                                    • 14684
                                    Very good on the U9850 replacement - we can rule this out. You are confident the replacement went well for the soldering ? 'Made it dance' with flux & hot air tool ?
                                    Perhaps reflow it if the ENABLE is logic '1' = means the MUX is enabled.
                                    Curious on the backlight voltage reading (PPVOUT_S0_LCDBKLT).
                                    If PPVOUT_S0_LCDBKLT is not 25+ volts then this rail is not working.
                                    Proceed to remove all power, meter in resistance mode (2k scale is ok).
                                    Check the resistance to ground of PPVOUT_S0_LCDBKLT (red meter probe) & black meter probe to ground. Checking for a low resistance which can cause this rail to be pulled down OR even shut off due to an excessive load (current draw).
                                    Post all readings.
                                    • Strolch
                                      • Nov 2017
                                      • 245
                                      • Deutschland
                                      Yes he danced, Flux+hot air!. Where else should I measure the voltage?
                                      • Strolch
                                        • Nov 2017
                                        • 245
                                        • Deutschland
                                        i have no backlight on the display nothing
                                        • CG_Dionysos
                                          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                          by CG_Dionysos
                                          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                          • Model: A1707
                                          • 15-inch, Mid 2017
                                          • 3.1 GHz Core i7
                                          • 16 GB RAM
                                          • Radeon Pro 560
                                          • 1 TB SSD
                                          • Board number: 820-00928-A
                                          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                          Thanks in advance!
                                          Greetings from Germany...
                                          09-16-2025, 06:43 AM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
                                        • iZakre
                                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                          by iZakre
                                          Hello everybody!
                                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                          The thing is that I had installed TeamViewer and could log into the computer...
                                          02-19-2023, 02:27 PM
                                        • gereute paule
                                          NEC PA241W-BK Status LED flashes 4 x Display remains dark
                                          by gereute paule
                                          Perhaps someone knows the problem with the NEC Spectraview display.
                                          When switching on, the green LED lights up briefly and then changes to red and flashes four times, pauses briefly and repeats until the power button is pressed. The screen remains off.
                                          The laptop is connected via Displayport and the screen is also displayed in the graphics properties.
                                          Any ideas?
                                          Thanks for answers.
                                          10-14-2023, 02:07 PM
