820-00840 / No boot / PP3V3_G3H Short to ground
  • MisterAIL
    • Oct 2021
    • 10
    • France
    Firstly sorry for my english, french guy inside.
    I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
    History is a day, nothing happened when opening the laptop.
    Nothing special inside, no corrosion, no liquid damage, never opened.
    First, with the logicboard alone on the desk, mesures are :
    5v017 and 0.000 amp. nothing else.
    Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H around 2 volts.
    To isolate the CC, removed L6995. Short was not before it, but after, on PP3V3_G3H_VR. No short on PP3V3_G3H (at this time). Removed all caps C6996/5/7/8/C6988/9, but short still there.
    Decided to remove the R6999. Then no short on PP3V3_G3H_VR (happy) but now PP3V3_G3H is shorted ! (around 0.002 on diode mode)
    Replacing L6995, plug-in USB-C charger => 5v017 on charger, 0.00 amp, but PP3V3_GH3_VR present (3.42 Volts). Replacing R6999 (the real mistake?) but nothing else. No short on PP3V3_G3H_VR (Pin 1 of R6999) but sill present on pin 2. I suppose resistance can isolate a short, because nothing is connected to the ground.
    Removing C7080 on PP3V3_G3H (the most easier before thinking at U7000) and... nothing more. I decided to leave the board beside.
    This morning, i plug the charger to make new tests, and, without touching nothing since the last day, charge stays at 5v017 but amp drop from 0.3 to 1.8 ! Nasty smell around U3100 and U3200... touching in the zone and burning my finger on Cap C3100... Damned !
    Charger pulling down to 0.6 amp and 4.7 volts on first usb-c port, stay around this values and, around 5v017 and 0,3 amp on other port...
    So i decide to take the mesure of PM_EN_P3V3_G3H => 5,17 volts !! how it's possible !
    I decided to remove C3100, C3200, and U7000. Unfortunatly there still a short on PP3V3_G3H, and another on the PP3V3_G3H_XPC_XA and XB. Not removed yet the R3000 and R3001 but i need your help before making more damage to the board...
    A idea for the nexts steps (without more destruction?)
    thanks a lot for your help
  • mon2
    • Dec 2019
    • 14691
    Re: 820-00840 / No boot / PP3V3_G3H Short to ground
    Remove R3000 & R3001 - one at a time to see if the PP3V3_G3H short is removed.
    I think you mean PP3V3_G3H_UPC_XA and XB.
    Perhaps one or both of the ACE (U3100 / U3200) controllers got zapped.
    • MisterAIL
      • Oct 2021
      • 10
      • France
      Yes of course, excuse my mistake. It's lines PP3V3_G3H_UPC_XA & XB
      So i remove the tinyyyyyy R3000 and 3001, one by one.
      Short is gone on PP3V3_G3H_UPC_XA and XB, so i suppose U3000 & U3001 chips are fines.
      But short on PP3V3_G3H is still there !
      I remove R6999 to be sure again, but no difference...
      With schematic, i'm a little bit confused what to test after that.
      • mon2
        • Dec 2019
        • 14691
        You have a short on PP3V3_G3H somewhere on the board. With 0 ohms, appears to be a hard short where dead caps are often low resistance ohms but personally have not seen 0 ohms on a bad cap.
        Remove the KEYBOARD cable and inspect the logic board keyboard connector with the meter to see if there is a possible short between pins 15 & 16.
        PP3V3_G3H_KBD == PP3V3_G3H
        Regardless, leave keyboard & R6999 out till the short is found.
        • MisterAIL
          • Oct 2021
          • 10
          • France
          Thanks for your reply mon2.
          Board is alone on my desk since the beginning, nothing plugged on it.
          Keyboard connector looks perfect, nothing special.
          However, values are below :
          Resistance from pin 15 to ground => around 2,6 ohms
          Resistance from pin 16 to ground => around 0,9 ohms (same as shorting my multimeter)
          Resistance from R6999 (pin 2) to ground => around 2,6 ohms
          So Pins 15 & 16 aren't shorted together, connector seems fine.
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • adelfr2009
            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
            by adelfr2009
            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
            09-28-2025, 10:21 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
