Dell E5440 completely dead
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    #61
    Re: Dell E5440 completely dead
    I'll try it and then i'll try bios dump, report in a while
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      #62
      Spider can you please give me your opinion on this ->https://www.badcaps.net/forum/showth...t=98968&page=2
      After a shortcircuit i have 20Ω short to the GND, same situation probably.
      From post #31 and so on.
      Thank you in advance.
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        #63
        Needed bios dump too, now power on but return LED error code "A possible processor failure has occurred."
        Perhaps a voltage is missing from what i solder OR cpu is indeed fried?
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          #64
          Try with a known good BIOS first. The check the voltage on all the coils with laptop ON. Post your results for each coil.
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            #65
            Just noticed this laptop has a EC chip too. Can you confirm it is U86 to flash it too?
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              #66
              U86 is an AND gate. KBC/SIO is U38 (MEC5075), it is programmable but I don't think its an issue. You'd need SVOD programmer for that. Chip also has 2 rows of pin, 1 visible on the side and another under the chip.
              Try a known good BIOS and post your voltage measurements.
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                #67
                I'm waiting for bios with confirmed vPro support, posted request in E5440 bios thread.
                After that i'll flash it and try again.
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #68
                  Fixed.
                  I replaced U1, i flashed the bios SMDFlea suggested and worked.
                  Never before seen a "A possible processor failure has occurred." LED error blink due to bad bios and/or bios chip.
                  Well i assume i learn as i live.
                  Thank you both!
                  Back to 7510 problem now that hunts me in my sleep.
                  • max-power
                    Dell E6540 laptop completely dead after dssasembly
                    by max-power
                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                    03-24-2025, 08:49 AM
                  • diamon
                    Dell Latitude 5520 completely dead
                    by diamon
                    I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                    Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                    After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                    Have checked with a thermal camera, and there are a couple of things...
                    03-05-2025, 02:23 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • gugutm
                    Dell Latitude 5410 dead help please.
                    by gugutm
                    hi everyone,
                    need some advice i am not professional just junior , but maybe someone could help me please
                    i have
                    Device : Laptop
                    Brand : DELL
                    Model : LATITUDE 5410
                    Board Number: FDZ41 LA-J371P Rev:1.0
                    i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
                    my problem is its not turning...
                    08-28-2025, 02:24 PM
                  • Francesc V.
                    Dell dockstation WD15 is dead
                    by Francesc V.
                    Hi:
                    A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                    Here are the findings, followed by good pictures. :-)
                    When pluged in, LED3 glows
                    Measuring some voltage in the circuit.
                    Inductors
                    - PL202 has 5V
                    - PL201 has 3.3V
                    - PL300 has 1V
                    V. Regulators
                    - UT30 has 19v as input and 6V as output. It seems ok.
                    - UT27 (same reference as UT30, has no input/output voltage).
                    Thermal find...
                    07-09-2025, 12:12 AM
