Dell E5440 completely dead
 Re: Dell E5440 completely dead
 Ok. So it seems most of the parts on the supicious rail were checkd, except PQ5 and PU701, right?Comment
 Unfortunately i can't find datasheet right no for PU701, but you can at least check whether 19V reach Pin1 and of course, you can check each pin for short to GNDComment
 How many amperes? Do you have a bench power supply? If yes, set it to 19.5V and power the board from it.Comment
 Check where the DC adaptor connects to the motherboard. Apply power from your power supply on the DC connector pins, just make sure which is +ve and -ve first.Comment
 PU701 Pin 6 & 15 short to GND means Main Power Rail short to GND. How could that Be missed before?Last edited by Sephir0th; 10-19-2021, 07:23 AM.Comment
 Do a visual check first to identify if something is physically damaged, otherwise Inject voltage on that line and see what gets hot. As always, start with 1V 1A then increase amp slowly if needed.Comment
 Did visual inspection before, totally clean mb.
 Gonna inject voltage and report in 2 minsComment
 First, Share exact Résistance to GND there in Ohms Mode, Range 200 or Auto-Range to exclude a Short with a step down Circuit.Comment
 20 Ohms are probably Bad News. Now you have to Check Resistance to GND of each coil. Look for a similar value...Comment
 I see same value only on PL400 (both pins) all other coils have values way beyond this.Comment
 That's fine then. So Voltage injection Like mentioned before. Pay Attention especially To PU401 and PU701.Comment
 I inject voltage on pin 6 (+) and GND (-), 1v 1a and drown only 0.4A, no shortcircuit indication.Comment
 They both share a common line through PR400. You could try removing PR400 to see which side is 20Ohms.
 I suspect it might be a faulty PU701. These are fairly easy to remove and resolder. I'd try removing it and see if the 20Ohms is still there. Or you could just inject voltage, but with 20Ohms at 1V, I doubt anything will get hot (expected 0.05A flow).Comment
			by max-powerHi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
 that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
 After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
			by diamonI have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
 Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
 After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
 Have checked with a thermal camera, and there are a couple of things...3 Photos
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by gugutmhi everyone,
 need some advice i am not professional just junior , but maybe someone could help me please
 i have
 Device : Laptop
 Brand : DELL
 Model : LATITUDE 5410
 Board Number: FDZ41 LA-J371P Rev:1.0
 i am attaching schematics and board view. [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...14#post3484414
 my problem is its not turning...
			by Francesc V.Hi:
 A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
 Here are the findings, followed by good pictures. :-)
 When pluged in, LED3 glows
 Measuring some voltage in the circuit.
 Inductors
 - PL202 has 5V
 - PL201 has 3.3V
 - PL300 has 1V
 V. Regulators
 - UT30 has 19v as input and 6V as output. It seems ok.
 - UT27 (same reference as UT30, has no input/output voltage).
 Thermal find...07-09-2025, 12:12 AM
- Loading...
