X1 Carbon Gen3 (20BT, 20BS) not turning on or no screen
  • randoomkiller
    • Oct 2021
    • 9
    • Hungary
    Hi, so I have the bestest of the best as the X1 Carbon 3rd gen (it should be 13268-1 from Wistron) and I have a few weird things on it and would be helpful if you could give a second opinion on it.
    First, for more than half a year now, the screen is (was) inhibiting the serial fault of having contact, so I'd have to apply pressure to the inverter to work.
    About 2 weeks ago I've spilled a little tea over the keyboard, then I turned it off, and did not do anything with it for a week. After that week I needed something that had webcam, but the keyboard was not accepting input, so I turned it off and taken apart since.
    I have been planning on upgrading the memory chips on it for a while now, because 8GB felt too little, and I felt like I would be up to the challenge, so I have the right kind (8pcs dual dye mikron 2GB/chip DDR3) as replacement.
    So, I thought while I get a new screen unit from ebay (because someone scrapped one, and put up a whole screen for 50EUR, which is a bargain), I would try to desolder the RAM chips.
    It did not work. It has underfill, that neither aceton nor alcohol can remove, however I've never encountered underfill before so it might have been possible that I was heat treating the Motherboard for 15-30 mins.
    Now the symptoms are : RED led is on when plugged in, it does seem to be charging the battery, however I see no screen at all.
    Another weird thing is that, whenever I turn it on, keyboard light is not visible, the power button shows to be on, HOWEVER even if I press it for a slight second it turns itself off. This is unusual, as usually to turn off you'd need 2-3sec, and the only time when I saw that it turned itself off like this was when it didn't have an SSD in it and told me an error code.
    No error code nor beeps were heard. No water damage is visible on the motherboard.
    My guess is that I've fried the old RAM chips, would that make similar symptoms?
    What do you think?
    P.S: I have also found a presumably "faulty" Motherboard on ebay for 8EUR of the same exact kind, and its on my way to here - it could be a good donor board. I also managed to get the schematics, both the boardview, and the PDF version.
  • randoomkiller
    • Oct 2021
    • 9
    • Hungary
    Re: X1 Carbon Gen3 (20BT, 20BS) not turning on or no screen
    Could a killed RAM chip produce a dead machine or should I look for something else?
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Sghypoe99
      Lenovo X1 Carbon Gen3 (20BS) LMQ-2
      by Sghypoe99
      I'm trying to create / extract the bios image from the Lenovo FL1 file for a Lenovo X1 Carbon Gen3 (20BS) LMQ-2, and would really appreciate some pointers.
      I've watched a couple of videos and read some guidance on Badcaps but it seems the FL1 file for this model seems different to the guides.
      08-28-2021, 03:20 AM
    • Sghypoe99
      by Sghypoe99
      Can someone help confirm the location of the bios chip on a Lenovo X1 Carbon Gen3, Motherboard LMQ-2.
      I think I've located it (see attached), but just want to make sure its not another chip e.g. TMP etc....
      08-27-2021, 04:31 AM
