Dell 6540 cmos battery ( no data )
  • Rekoo1997
    • Oct 2018
    • 26
    • Egypt
    Hi
    Dell model : la-9411p
    Laptop it working power only (no data ) if connect cmos battery but if remove cmos battery and turn on laptop working fine but if restart no data
    I have tried flashing more bios
    And cleared me but still problem
    Please call help me
  • mon2
    • 14677
    Re: Dell 6540 cmos battery ( no data )
    Hi.
    What is the meaning of 'no data' ?
    The cmos battery is used to hold your real time clock settings, the hardware configuration like hard drive parameters, the boot priority, etc.
    Is this what is lost when you remove the CMOS battery? This is normal.
    • Rekoo1997
      • Oct 2018
      • 26
      • Egypt
      Originally posted by mon2
      Hi.
      "No data " I meaning the laptop running power but no display and no response
      And power supply current 1.2 amp
      But if I remove cmos battery all things working fine
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I faced the same issue on a latitude E6420 LA-6591P. It was resolved by flashing bios though i tried atleast 7-8 dumps and fortunately one worked. So very likely its a bios issue.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • questore
          XPS 13 9370 CMOS battery voltage always low
          by questore
          Hi Everyone,
          I have brought you a mistery item
          This laptop have come with some strange faults.
          1. CMOS battery was flat 0v
          Symptoms:
          - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
          Amp drawing was stuck at 0.005 milliamps.
          - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
          After inverstigation RTCD1 diode had a low value...
          09-30-2025, 05:47 AM
        • tomodachi
          Dell Precision 5510 " Not a Dell Battery"
          by tomodachi
          Hi
          Dell Precision 5510
          Mobo code : LA-C361P
          This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
          The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
          So we ordered a geniune battery for customer, plugged it in
          RTC battery was also dead and it was also replaced. First boot up brought up warning message;
          Funny thing is Service Tag is already set.
          And...
          11-07-2024, 06:08 AM
        • lawrenceptrini
          Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
          by lawrenceptrini
          Hi Guys,
          I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
          The laptop is working fine with the adapter plugged in and also with a charged battery.
          Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
          ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
          loses its charge, it stays on 0%.
          Measurements taken
          Charging IC (ISL95522HRZ) 32 pins
          Voltage to ground with ac adapter only plugged in:
          1)...
          08-26-2024, 06:45 PM
        • ianbak
          Dell Vostro 3578 Battery Error
          by ianbak
          Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
          The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
          The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
          10-17-2025, 02:52 AM
