can i use RT6575B instead of TPS51225
  • bembeno
    • Feb 2016
    • 309
    • egypt
  • RichBon
    • Apr 2019
    • 54
    • Ghana
    Re: can i use RT6575B instead of TPS51225
    no
    • bembeno
      • Feb 2016
      • 309
      • egypt
      thank u bro
      • carlosefren
        • Dec 2017
        • Ecuador
        yes
        https://www.richtek.com/Design%20Sup...?Keyword=51225
        • bembeno
          need alternative ic for tps51225
          by bembeno
          10-06-2021, 09:08 AM
        • master3112
          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
          by master3112
          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
          10-29-2024, 09:32 PM
        • elmann
          Dell Insipiron missing EN ALWSON
          by elmann
          Hello everyone, I have a Dell Inspiron 15 laptop, motherboard dell vegas 15341-1.
          The laptop does not start, does not provide 3.3V ALWS and 5V ALWS because it does not receive enable from EC (ALWON signal is missing). The ISL circuit provides ACOK for EC but EC no longer provides ALWON for the 3.3V and 5V ALWS source built with TPS51225. EC is supplied with 3V from 3VLDO from TPS51225. On the power button I have 3V and it reaches EC.
          EC is on page 24 in the attached file.
          Please tell me what other conditions can inhibit EC that not to provide ALWON? I looked at the schematic,...
          08-27-2023, 10:11 AM
        • randomrat
          Alienware X15 R2 LA-L611 No power
          by randomrat
          ​Not having the best of luck with my own gadgets atm - I own two identical X15 R2 laptops, both have died suddenly with no prior issues. I have time to focus on one of them and in this post. I might need some hand-holding with this so I kindly ask for some understanding
          Make: Alienware
          Model: X15 R2
          Motherboard: LA-L611
          CPU: i9-12900H
          GPU: RTX 3080Ti
          History: I was using the machine as normal when it suddenly switched off and never came back on. I've owned the machine for over a year and use a Dell Thunderbolt Dock to charge my laptop with....
          03-29-2025, 12:18 PM
        • MicroSMD Lab
          MSI MS-16W1 no power, EC replaced by other.
          by MicroSMD Lab
          Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
          03-27-2025, 07:35 AM
