Dell Insipiron missing EN ALWSON
  • elmann
    • Nov 2022
    Hello everyone, I have a Dell Inspiron 15 laptop, motherboard dell vegas 15341-1.
    The laptop does not start, does not provide 3.3V ALWS and 5V ALWS because it does not receive enable from EC (ALWON signal is missing). The ISL circuit provides ACOK for EC but EC no longer provides ALWON for the 3.3V and 5V ALWS source built with TPS51225. EC is supplied with 3V from 3VLDO from TPS51225. On the power button I have 3V and it reaches EC.
    EC is on page 24 in the attached file.
    Please tell me what other conditions can inhibit EC that not to provide ALWON? I looked at the schematic, but I can't tell if the EC is faulty or is it something else.
    Thank you
    MOD Edit: Link to schematic - https://www.badcaps.net/forum/showthread.php?t=79497
  • elmann
    • Nov 2022
    Re: Dell Insipiron missing EN ALWSON
    The EC chip does not have an external quartz crystal, it has an internal oscillator, at pins 123 and 125, where the quartz crystal would have been connected, I have no signal. If the oscillator is internal, should there be an oscillatory signal on them or not?.
    The rest pin RESET OUT pin (73) is zero but I don't know if it is in the reset state or EC is not working and that is why it is in zero?
    There is a 32625 Hz RTC signal on the CPU but the clock signal does not come from the CPU to the EC on pin 25
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • multitech
      Dell G7 7588 LA-E994P missing +VCC_CORE
      by multitech
      Hi everyone, i got a Dell G7 7588 missing +VCC_CORE and +VCCGT, i have already checked the power on sequency, everything seens to be fine, i also have PCH_PLTRST# signal present.
      the laptop turns on but no video.
      i flashed a new BIOS and also Clean ME, same issue.
      i already replaced PU5000 NCP81215D
      DRVON 4.75v
      VR_RDY 3.3v
      EN 3.3v
      +VCCSA 1.04v
      +VCC_CORE resistance is 4ohm.
      no GPU power also but if i remove the +VCCSA coil i have the GPU powered and the VRAMs.
      Thank you.
      01-31-2025, 10:32 AM
    • PacoGT
      i need schematic or help missing components DELL LA-C642P
      by PacoGT
      I'm looking for the schematic or the numbering of the components that are missing on this board since they brought it to the workshop but without the parts and I can't find the schematic or anything about this board
      DELL LA-C642P
      THANKS
      08-28-2024, 06:29 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
