820-3437 no backlight
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    i recieved macbook air A1466 820-3437..
    checked..no backlight..disassemble and have water damage on the dc in board connector (flexible conenctor).
    now i focus on backlight first..
    on start up i have chime and backlight on for 1 second but suddenly off
    PPHV_S0SW_LCDBKL 24V WHEN CHIME
    BKL_PLT_RST_l 3.3V
    EDP_BKLT_EN 3.3V
    LCDBKLT_DISABLE 0V
    LCD_BKLT_EN_L 0V sometimes 8.5v
    LCDBKLT_BOOST 8.6V
    PPVOUT_SW_LCDBKLT_FB 24V and drop to 8.5V
    measure all the resistor near U7701 all ok
    change U7701 2 times but still the same
    any help will be appreciated...thanks before
  • mon2
    • Dec 2019
    • 14677
    Re: 820-3437 no backlight
    Hi. From memory, the A1466 820-00165 has current sense circuit on this backlight rail. Guessing that your logic board will as well. Check to see that current sense circuit is ok. What is voltage going into the current sense circuit? What is the voltage leaving? If this circuit is not complete, the logic board may sense incorrectly that there is a fault and shut off the rail after sampling the false current draw for the backlight.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      already tried with another lcd but still the same
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        i believe the current sense resistor is R7788 and R7789 right?
        the value is ok and the voltage runs through it is 8.5V
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          my bad...the current sense resistor is R7717, R7718, R7719, R7720, R7721 and R7722 and all 4.5V when chime and drop to 0.9V slowly
          • piernov
            • Jan 2016
            • 4439
            • France
            DC-in board contains lid sensor. Must be working to get backlight.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              100% correct @piernov thanks for the help...but which line connect to lid sensor?
              • piernov
                • Jan 2016
                • 4439
                • France
                Schematics/boardview → Ctrl+F "lid"
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  thanks @piernov
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                  • DanPoka
                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                    by DanPoka
                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                    02-15-2025, 05:05 AM
                  • Comp_Pro
                    No Backlight Macbook A1990 820-01041
                    by Comp_Pro
                    Hello all,
                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                    Tests performed:
                    There is no backlight even with a good screen.
                    Backlight IC is receiving the correct support voltages.
                    Fuse F8400 ok
                    Current sense resistor R8400 ok
                    Backlight IC is receiving 3.3V on enable pin.
                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                    Backlight IC receiving 5V from PP5V_G3S
                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                    05-06-2024, 10:23 PM
                  • avisonjohn
                    LG 34UM68 backlight and 'chime' on start up, but no OSD or video
                    by avisonjohn
                    I have an LG 34UM68 with board EAX66876002 but it has issues with not working correctly.
                    It powers on, backlight comes on, but there is no OSD shown, and no video shown on the screen.
                    I checked over the board for any obvious visual damage, and everything looked OK.
                    I then took a dump of the main SPI Flash chip.
                    I tried to take a dump from the EEPROM, but it would sometimes read data correctly, and other times would had obvious reading problems.
                    I managed to get a dump from it which somewhat resembled correct data - part of the...
                    10-30-2023, 09:23 AM
                  • cheebster
                    iPad Pro 12.9 5th Gen Backlight Issue
                    by cheebster
                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                    Anyone...
                    05-20-2025, 09:17 AM
