Razer Blade Pro 17 2019 Dead
  • amihail
    • Aug 2021
    • 12
    MOD EDIT: Posts split to new thread from https://www.badcaps.net/forum/showthread.php?t=95054
    Sorry for necro bump but what exactly was the fix here? I have the exact same issue ... seems like my "C1" completely blew/fell off though.
  • mon2
    • Dec 2019
    • 14229
    Re: Razer Blade 15 Advanced (2019): BIOS Programming gone wrong
    C1 will not be missed in the operation of this flash IC. It is common practice for digital designers to apply a local despike capacitor to suppress regional noise on the power line. While it is nice to have, it is not critical to have.
    Often the part is 0.1uf and any voltage rating of the capacitor > than the operational voltage will work. For example, 4v or 6v3, etc. is fine.
    Guessing from the pictures, it is 0402 or 0603 in SMD size.
    • amihail
      • Aug 2021
      • 12
      Again my bad for necro bump - I am not able to make my own thread yet. I've experienced the exact same turn of events as OP and I've ended up with a dead machine - techie I left it in with says there is damage here but does not know what to replace it with.
      EDIT: Forgot image:
      https://imgur.com/a/qNTbfYy
      • amihail
        • Aug 2021
        • 12
        doublepost
        • mon2
          • Dec 2019
          • 14229
          The missing C1 may even be 0201 in size. They are dirt cheap and available @ Arrow.com but as noted, this will not stop the proper operation of the flash device.
          Hope you still have the flash device?
          If you really want to source the C1 cap (or equivalent), send me a PM and should be able to drop ship them. Again, guessing that it is 0201/0402 in size - one of these has to fit the pads.
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            u can try with 0.1UF 0201 capacitor on vcc pin 8 and 33omh 0201 1/20 watt resistor on pin 7
            • amihail
              • Aug 2021
              • 12
              Thanks for the reply!
              Haha yes, the chip was removed to verify contents with original Razer ROM - it is showing the same contents in CH341A software & flashrom and sha256sum.
              Are you certain that's what missing in the photo? Techie says there is a component missing here and BIOS chip is not receiving any power at all preventing boot up - it is not a BIOS chip contents issue he says.
              • amihail
                • Aug 2021
                • 12
                Are you saying you think 2 parts are missing? :S
                • mon2
                  • Dec 2019
                  • 14229
                  See attached,
                  • amihail
                    • Aug 2021
                    • 12
                    See attached,
                    Maybe there's some confusion - the photo in the bottom right is just the area you've drawn a green box around zoomed in further - as far as techie says voltage is 0 going into the chip.
                    • mon2
                      • Dec 2019
                      • 14229
                      Got it. Then we are back to the single 0201 (most likely in size) despike cap only that is not required.
                      Post the voltage of the resistor in the same picture on the right side. Do you see a voltage going into this resistor?
                      From your tech, there is no voltage on pad # 8 of this flash device ? (it is the same pad that is missing the capacitor). The capacitor should be +V on pad # 8 and ground on the other side of the pad.
                      • amihail
                        • Aug 2021
                        • 12
                        Techie is saying chip receiving voltage today but doesn't know why :S - 3.3v coming in on that pad as should be ... still no life about the laptop though, no screen keyboard lights or fan spin up - maybe chip contents after all? Will the machine boot with a lower version of ME externally flashed on there?
                        • amihail
                          • Aug 2021
                          • 12
                          Or is it possible for CH341A to read/write a chip that's actually been burnt out by it's 5v output?
                          • amihail
                            • Aug 2021
                            • 12
                            Bump - still a dead board and out of ideas. Techie gave it back for free and couldn't fix.
                            • amihail
                              • Aug 2021
                              • 12
                              Rewriting chip now shows keyboard lights but turns off immediately !?
                              EDIT: This chip showing as empty (all FFs) most definitely need a dump from this machine to compare to now.
                              https://imgur.com/a/u5hqVXM
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                Re: Razer Blade Pro 17 2019 Dead
                                google "razer blade pro 17 bios dump"
                                first link has a tutorial to get bios from razer site, extract and program with asprogrammer and ch341
                                • BalkanBoy
                                  Dead Razer Blade 14 2022, shorted CPU?
                                  by BalkanBoy
                                  today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                  Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                  I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                  Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                  I removed coil and injected 0.7V, it draw around...
                                  09-27-2024, 12:44 PM
                                • Razor0601
                                  Razer Blade 15 advanced Late 2019
                                  by Razor0601
                                  Hello, I bought a Razer blade 15 advanced with I7-9750h and RTX 2080 without Display. Seller said it works with external display. It arrived and I connected it to my Samsung TV. It gave me an external Pic with windows 11 start screen. But I had no Windows account so I removed the SSD and installed it in my other laptop to install windows 10. put it back in the Razer but from this time I never got an external pic. Can anybody help me to get back an external pic?
                                  BTW: I‘m sure the LCD-cable is bricked and not the LCD itself.
                                  09-15-2023, 04:57 AM
                                • theplop
                                  Razer blade 2022, 14" PI480 wont boot to OS, freezes
                                  by theplop
                                  Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
                                  I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
                                  I've run memtest quite a few times, and more often then not...
                                  03-20-2025, 06:42 PM
                                • shellybelly
                                  Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                  by shellybelly
                                  Back Story
                                  I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                  So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                  08-27-2023, 10:40 PM
                                • bumper1
                                  Looking for schematic or bv for Razer Blade 15 RZ09-0328 MOBO: DA550-MB
                                  by bumper1
                                  MOBO: DA550-MB MP V4.0 20200227
                                  07-10-2025, 03:40 AM
