HP 14-dfoo18wm" Touchpad problem
  • andresi
    • Nov 2020
    • 151
    • INDONESIA
    Hi sir,
    so i have Hp 14 with code board hedwig-6050a2993001-mb-a03 the problem is Touchpad cant working, but in power on condition i pull out and pull in again the flexible touchpad working normal and i restart again my laptop the touchpad cant working again. anyone can have solution?
    help, thanks
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: HP 14-dfoo18wm" Touchpad problem
    is windows formatted in full uefi ?
    • andresi
      • Nov 2020
      • 151
      • INDONESIA
      yes its full uefi
      • andresi
        • Nov 2020
        • 151
        • INDONESIA
        Originally posted by andresi
        yes its full uefi
        btw, the porblem come after replace new keyboard
        • andresi
          • Nov 2020
          • 151
          • INDONESIA
          Solved After Reinstal Windows to Legacy
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            try to reinstall it in full uefi. and see if all works fine.
            • Test asus
              ASUS X542UR Touchpad problem
              by Test asus
              My laptop's touchpad is not working. I have tried software, touchpad and touchpad fpc. I think the motherboard is faulty, can you share motherboard schematics or how can I fix the problem?
              Model
              X542UR-GQ272T
              Part No
              90NB0FE2-M03490
              Part Desc
              AS X542U 7500U/1DG5/12G/TU
              Part Specification
              X542UR-1BGQ/8SL/V/WAC/A08
              Have a good day,...
              04-25-2024, 03:40 AM
            • Kingblue
              Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
              by Kingblue
              Hi im new here and i hope you guys can help me maybe.
              I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
              So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
              It was booting perfectly. i played a clean win 8.1 on it.
              After installing all and update all to the last drivers it was running very good.
              Thinks that dont worked
              Keyboard back lights and cant start with fn+f4 all other fn+f working
              3 of the 4 USB 3 Ports are not working.
              the...
              03-20-2024, 05:31 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • DaBotta
              Thinkpad X240 Touchpad Problem
              by DaBotta
              Hello ,
              I have an X240 i7 Thinkpad.
              The problem is , that the touchpad don't work , tried allready with another touchpad , and same , not working.
              And another think , the FN lock key not work , when i press FN + ESC don't lock or unlock the FN function , the led from the keyboard don't turn on or off. Tried even with another keyboard.
              I allready tried to update bios to the last version , but didn't solve the situation.
              Can be a mainboard problem ?
              Thank you
              01-22-2022, 09:41 PM
            • emaghanim
              Hp ElieBook 1030 g4 touchpad problem
              by emaghanim
              Hi
              First
              f10 key led always on event in power off
              touch pad doesn't work only if i close the lid / Screen and open it again while power on as in video
              some how when lid sensor is closed and opened again it reset enable touch pad
              i search for board view or schematic not found
              how to enabled touch pad ?
              any one seen this before can help
              thanks...
              12-15-2024, 07:35 AM
