Hp ElieBook 1030 g4 touchpad problem
  • emaghanim
    • Dec 2014
    • 133
    • egypt
    Hi
    First
    f10 key led always on event in power off
    touch pad doesn't work only if i close the lid / Screen and open it again while power on as in video
    some how when lid sensor is closed and opened again it reset enable touch pad
    i search for board view or schematic not found
    how to enabled touch pad ?
    any one seen this before can help
    thanks
  • emaghanim
    • Dec 2014
    • 133
    • egypt
ID:	3529383 Click image for larger version
    Any one got this touch pad pinout
    does this touch pad chip have enable pin ?
    any help ?? ​
    • Test asus
      ASUS X542UR Touchpad problem
      by Test asus
      My laptop's touchpad is not working. I have tried software, touchpad and touchpad fpc. I think the motherboard is faulty, can you share motherboard schematics or how can I fix the problem?
      Model
      X542UR-GQ272T
      Part No
      90NB0FE2-M03490
      Part Desc
      AS X542U 7500U/1DG5/12G/TU
      Part Specification
      X542UR-1BGQ/8SL/V/WAC/A08
      Have a good day,...
      04-25-2024, 03:40 AM
    • trepachka
      Converting HP EliteBook 840 G7 non-touch to touch if possible
      by trepachka
      I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
      The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
      I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
      04-27-2024, 11:15 PM
    • Prott
      Surface Pro 4/5 - no touch after LCD change
      by Prott
      I have a question that's driving me a bit nuts recently.
      Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
      - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
      - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
      01-25-2023, 12:42 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Kingblue
      Asus G750JX/JW problem with kb lights, USB ports and touchpad / Bios Problem?
      by Kingblue
      Hi im new here and i hope you guys can help me maybe.
      I buyed an old Asus G750JX and the seller told me it was running perfect after shutdown it never bootet again.
      So i buyed this G750JX and open it. after cleaning and checking all inside i startet it.
      It was booting perfectly. i played a clean win 8.1 on it.
      After installing all and update all to the last drivers it was running very good.
      Thinks that dont worked
      Keyboard back lights and cant start with fn+f4 all other fn+f working
      3 of the 4 USB 3 Ports are not working.
      the...
      03-20-2024, 05:31 AM
