toshiba c55
  • didouche1200
    • Oct 2016
    • 359
    • 82679911441
    toshiba c55
    when battery attached laptop don't work red power light on ; any idea
    motherboard da0bljmb6c0 rev c
    battery is good
    • 21282
    Re: toshiba c55
    Post everything youve tested as we don`t know ? .Voltages etc
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Another project idea for a battery bought from Battery Hookup with a good BMS board
      https://batteryhookup.com/products/n...-2900mah-cells
      One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
      The price of this offer has gone up sense I bought these two boxes
      I bought two boxes of these batteries but there is a catch to the these battery packs
      The BMS protection board does work but it...
      07-31-2022, 04:07 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
