Hp 14-bs000 - da00p1mb6d0 rev d
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Good afternoon,
    I have this pc that only turns on the first time and works normally. If the pc is turned off, it will not turn on again until the charger and battery are removed.
    Can someone give me some lights to find the problem?
  • mon2
    • Dec 2019
    • 14157
    Re: Hp 14-bs000 - da00p1mb6d0 rev d
    Hi.
    1) try with only the adapter attached / removed. Does this work?
    2) check the adapter voltage at the dcin. Voltage?
    3) remove the adapter and check each mosfet resistance for possible shorts starting at the dcin section.
      • 20842
      maybe a RTC circuit problem
      • reformatt
        • Feb 2020
        • 1408
        Had something similar on a Lenovo, and it turned out to be a bad power button (well actually it was a damaged PCB trace). Only reason it worked initially is that when battery/power removed, it was doing a CMOS reset and automatically booting.
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
        • HERETIK10
          Adaptable charger voltage for Clevo D901C laptop
          by HERETIK10
          Thanks in advance to anyone who takes the time to help me. Sorry for the quality of my English, I had to use a translator at times...
          I bought a functional Clevo D901C (Sager NP 92261) with its battery but without its power supply.
          So, I invested in a new LiteOn charger, advertised by an online seller as the right charger for my machine... BUT, according to the pinout (4pin + shell) of the charger, 1 and 2 are 20V / and 3 and 4 are grounded. When I measure pin 4 with the ground of the PC, I have 300kOhms, which seems to be confirmed by the electrical...
          11-08-2023, 04:24 PM
