Hp 14-bs000 - da00p1mb6d0 rev d
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Good afternoon,
    I have this pc that only turns on the first time and works normally. If the pc is turned off, it will not turn on again until the charger and battery are removed.
    Can someone give me some lights to find the problem?
  • mon2
    • 14667
    Re: Hp 14-bs000 - da00p1mb6d0 rev d
    Hi.
    1) try with only the adapter attached / removed. Does this work?
    2) check the adapter voltage at the dcin. Voltage?
    3) remove the adapter and check each mosfet resistance for possible shorts starting at the dcin section.
      • 21907
      maybe a RTC circuit problem
      • reformatt
        • Feb 2020
        • 1505
        Had something similar on a Lenovo, and it turned out to be a bad power button (well actually it was a damaged PCB trace). Only reason it worked initially is that when battery/power removed, it was doing a CMOS reset and automatically booting.
          NVDC charger configuration...
          11-05-2024, 03:28 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Johndill
          Dell Inspiron 7567 LA-D993P odd charger issue
          by Johndill
          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
          Here are the tested scenarios:
          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
          2. With the laptop off, plug in charger (LED says on) & the front charging...
          11-16-2022, 10:55 PM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
