Macbook Pro 13" A1278 820-2936-B three beeps
  • GfilipeZ
    • May 2021
    • 43
    • Portugal
    When i turn on the Macbook, it sounds 3 quick beeps each 3 seconds.
    I've already swapped memories each slot; tested with new memories; checked screws on slot; checked pads soldered on Logic Board and still the same problem.
    I read it also could be faulty Bios, or faulty graphic memorie? Am i right?
    What else can i check?
  • mon2
    • 14659
    Re: Macbook Pro 13" A1278 820-2936-B three beeps
    https://discussions.apple.com/thread/8489222
    • GfilipeZ
      • May 2021
      • 43
      • Portugal
      Still the same problem, 3 beeps, no boot no image.
      Tried reset SMC and PRAM.
      • Adogabriel100
        Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
        by Adogabriel100
        Hey! This is a A1278 macbook 2011.
        Problem: Not turning on / No green light
        Im using by3200s charger.
        Voltajes:
        PPBUS_G3H = 12.26v
        SMC_RESET_L = 3.3v
        PP3V42_G3H = 3.42v
        U7000 =
        Pin 1 CHGR_AGATE = 0v
        Pin 2 CHRG_DCIN = 19v
        Pin 3 CHRG_ACIN = 4.6v
        Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
        Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
        Pin 12 PP3V42_G3H = 3.42v
        Pin 13 CHRG_RST_L = 3.3V
        Pin 14 SMC_BC_ACOK = 0.8V
        Pin 19 PP5V1_CHRG_VDD = 5.05V
        Pin 20 PP5V1_CHRG_VDDP = 5.03V...
        04-01-2024, 01:02 PM
      • Rezendes
        Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
        by Rezendes
        Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
        I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
        The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
        05-10-2024, 02:18 PM
      • pcbmaniac
        MacBook A1278 (3115) No PPBUS_G3H Issue
        by pcbmaniac
        Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
        I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
        1. U7000 Measurements:
          • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
        2. Resistors:
          • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
        Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
        • If I also decide to replace the SMC, do I need to order it pre-programmed,
        12-02-2024, 04:12 PM
      • sizar00740
        macbook pro 13 inch a1278 820-2879
        by sizar00740
        please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
        07-30-2025, 10:21 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
