a1286 820-2850 Charging problem.
  • reassor
    • Apr 2021
    • 181
    • Poland
    Battery is ok - can charge it on diffirent mobo (not same model - BUT simillar stuff around battery port.
    So to the wierdness now.
    Battery in it works fine - shows how much is charged etc.
    When i plug magsafe it sits at green then jumps to red for few secs and back to green (mac on or off) wierd part is when it switches to red my psu shows over 7amp draw but stays at 18.5V and watts do not go up O_o.
    On diffirent mobo (this one is not starting - dead gpu) it never goes over 3 amps.
    Any obvious susspects?
    I might be a morron so dont be rude
  • reassor
    • Apr 2021
    • 181
    • Poland
    Re: a1286 820-2850 Charging problem.
    Burned part of isl - curent sensing 10 ohm ressistors + 1 mossfet.
    Still no charging - battery has around 70% - no boot from battery
    No boot from charger (unless i hold power and put charger in then release power after like 5-10 sec
    • reassor
      • Apr 2021
      • 181
      • Poland
      any 1 know if there is a diffirence between ISL6259 and ISL6259A???
      thx and after that ignore this topic - i think i fried SMC :/ (no more bypass)
      • Scoff
        HP Probook 470 G4 - Power and Charging Problem
        by Scoff
        Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
        Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
        07-03-2023, 09:28 AM
      • ahmarzo
        Hp laptop charging problem
        by ahmarzo
        Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
        Charging ic is bq737 with voltages on pin no
        1&2 -19v
        34&5 -0v
        6 -2.56 v
        7- 0v
        8&9 -3.15v
        10 -0v
        11 -0.18v
        12 & 13 -13v
        14&15 -0v
        16 -6v
        17;18&19 -13v
        20 - 19v
        Voltages on battery connector are
        1&2. -13v
        3&4 -3.14 v
        5&6 -0v
        8&9 are ground...
        03-20-2025, 05:13 AM
      • roman728
        Lenovo E15 / NM-C421 Charging Problem
        by roman728
        Hello guys,
        I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
        02-20-2024, 03:40 AM
      • kity92
        Edifier x3 Earbuds Blue Light Problem (Charging Problem)
        by kity92
        I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
        Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
        01-13-2022, 01:49 PM
      • delphi_firebird
        Toshiba Qosmio X755 Charging problem
        by delphi_firebird
        Hello Guys,
        I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
        - When battery is unplugged i works without any problem.
        - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
        - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
        Can you help me diagnose the problem? I have attached...
        10-16-2023, 03:04 AM
