Problem backlight toshiba ar10sucu
  • cacascacas
    • May 2017
    • 8
    • espain
    Hello
    I have a toshiba laptop with ar10sucu motherboard,
    Disconnect the lcd cable without removing the battery and now no image appears on the screen,
    by hdmi if the image is seen
    can you help me
    Thank you
  • electrocute
    • Mar 2021
    • 23
    • spain
    Re: Problem backlight toshiba ar10sucu
    Hello.
    Is there no image or a dimmed screen (no backlight)? You can check the screen with a flashlight.
    Do you have a spare screen panel (either a partially broken one) to confirm a damaged screen or rule it out?
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
    • Dancauac
      820-01598 EDP cable was disconnected whist testing new screen. No image, no backlight
      by Dancauac
      MBP2019 A2159 Board 820-01598
      Hi Everyone! My very first question and ask for help! Thanks in advance!!!
      I was testing the new screen on this MBP but the time I was maging to turno the mac over, the EDP cable got loose.
      I disconnected the power, reconnect de EDP cable, holding with screws the screen this time.
      Turns on fine, everything works fine, but no image (I used the flashlight) and no backlight at all.
      Done SMC and PRAM reset. Nothing changes.
      Tested other functional aftermarket and original screens. Nothing changes.
      Don“t...
      03-29-2023, 02:38 PM
    • 1centchips
      A2485 no image and no backlight after chip transplant on new screen.
      by 1centchips
      Removed the two chips from the broken lcd at 350C and 40 air by properly protecting rest of the area with copper and kapton tape.
      Did the same with the new replacement panel.
      Reballed the pulled chips and installed on the new lcd panel at 250C and 40 air
      I have done few ones before without issue.
      The new panel was working before I transplanted the chips. Now the computer turns on and boots but no image/ backlight. (
      Anybody face this issue before?
      10-22-2024, 07:34 PM
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • harp
      emachine G725, screen backlight problem in OS
      by harp
      I have laptop emachine G725, which suffer from some backlight issue or feature.
      On hdd is installed linux, winxp and win7 with grub menu...
      Everytime when booting, laptop start up with full brightness, which is iritating.
      In stage where wait in grub menu, backlight can be manualy adjusted throu keyboard Fn+left, right... no problem, but whatever is choosen in this stage stay permanently locked when operating system boots up, so no more fn+left, right not working anymore in OS session. This behaveour is for linux and winxp, for win7 always boots with full brightness...
      05-09-2023, 03:25 PM
