Dell n5110 board does not shutdown
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Hi to all experts/seniors/learners,
    Dell n5110,
    If we shutdown it, only screen off but board remains on (power button has to press to off the board eventually).,.,any valuable guidance is highly appreciated.
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Re: Dell n5110 board does not shutdown
    Boot from USB stick with Ubuntu, shut down in that system and report results.
    • usyusy
      • Sep 2021
      • 171
      • Pakistan
      thanks you sir, just followed your instructions, its shut-down quickly.
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Problem is with the Windows install then. Perform a clean install and problem should be solved. Sometimes additional drivers might be needed.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • Garret Matt.
          DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
          by Garret Matt.
          I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
          Thank you in advance for any assistance you can render.
          Inductor In question. Buzzes like...
          06-20-2025, 01:21 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
