Dell Precision 7510 charge battery and left side board problem.
  • Andreasbest
    • Aug 2014
    • 1180
    • Hellas ( Greece )
    Hello friends!
    I have a Dell Precision 7510 with 2 problems.
    1) The battery doesn't charge and gives (in BIOS) a "Communication error" message. I want to know if the problem is in the battery itself or in MB.
    2) The left side mini board (the one with Type C, HDMI, MiniDP & 1x USB 3.0) prevents the laptop from power on more than one time.
    Without the board the laptop power on and off normally and works great, with it attached powers only once and if switched off doesn't power on again.
    Schematics attached
    Thank you in advance!!!
    • 21381
    Re: Dell Precision 7510 charge battery and left side board problem.
    Is there any damage on the daughter board ,all pins straight etc. Is the battery a genuine one.
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      Please post good pictures of both boards.
      • Andreasbest
        • Aug 2014
        • 1180
        • Hellas ( Greece )
        Hello, sorry i forgot the pictures. Atrached now.
        @SMDFlea the battery is genuine and the side board looks fine BUT the laptop (including some drops on battery and side board) suffered water damage, i cleaned everything and works fine except these 2 issues.
        Can we check if the communication between MB and battery is fine?
        • Andreasbest
          • Aug 2014
          • 1180
          • Hellas ( Greece )
          Good news.
          One of my customer's will bring me his 7510 for Windows 10 installation.
          We'll be able to test a lot of things with a fully working machine and first the battery.
          • FrozenHaxor
            • Jun 2015
            • 260
            • Poland
            Good thing, you'll be able to cross check.
            There appears to be SPI memory ICs. Dump the contents from the client's board, issue may be with them.
            Another one could be the bigger BGA IC that looks like USB 3.0 controller, sometimes they go bang and short data lines.
              • 21381
              There`s 2 SPI memory ICs ,UT1 and UT20
              • Andreasbest
                • Aug 2014
                • 1180
                • Hellas ( Greece )
                Ok the fully working 7510 is here.
                Fact #1: the battery from the faulty one is working like it should and charges fine. So the "communication error" is MB problem.
                • Andreasbest
                  • Aug 2014
                  • 1180
                  • Hellas ( Greece )
                  I don't care much about the side board, it's for 40€ on eBay, i want to check some stuff on it but i'm not gonna waste your time with it.
                  I care mostly about the battery "communication error" since it's definitely a MB problem.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Check PBAT_SMBCLK & PBAT_SMBDAT lines:
                    1. Resistance to dround
                    2. Voltage
                    Check PBAT_PRES#: resistance to ground with and without battery connected.
                    Check PR3: resistance between: 4-5; 3-6; 2-7
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • FrozenHaxor
                      • Jun 2015
                      • 260
                      • Poland
                      What's the battery model? Can you probe SDA and SCL lines with a scope on the battery connector?
                      • Andreasbest
                        • Aug 2014
                        • 1180
                        • Hellas ( Greece )
                        2. Voltage
                        PBAT_SMBCLK & PBAT_SMBDAT lines: Measured them on RP5, 7 and 8 pins.
                        1. Resistance to dround: No resistance to GND
                        2. Voltage: 3.3v both pins
                        Check PBAT_PRES#: resistance to ground with and without battery connected: Can't find a component to measure it. Any ideas?
                        Check PR3: resistance between: 4-5; 3-6; 2-7: 4-5 100Ohm 3-6 100 Ohm 2-7 100Ohm
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          SMBUS clock and data have to be checked with diode mode to ground.
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            So far so good.
                            Pin7 at PR3 - measure resistance to ground without battery connected, then measure the voltage with and without the battery.
                            • Andreasbest
                              • Aug 2014
                              • 1180
                              • Hellas ( Greece )
                              So far so good.
                              PR3:
                              Battery only
                              1 0v
                              2 0v
                              3 3.3v
                              4 3.3v
                              5 3.3v
                              6 3.3v
                              7 0v
                              8 0v
                              Charger only
                              1 0v
                              2 3.3v
                              3 3.3v
                              4 3.3v
                              5 3.3v
                              6 3.3v
                              7 3.3v
                              8 0v
                              Battery and Charger
                              1 0v
                              2 0v
                              3 3.3v
                              4 3.3v
                              5 3.3v
                              6 3.3v
                              7 0v
                              8 0v
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                PR3:
                                Battery only
                                1 0v
                                2 0v
                                3 3.3v
                                4 3.3v
                                5 3.3v
                                6 3.3v
                                7 0v
                                8 0v
                                Charger only
                                1 0v
                                2 3.3v
                                3 3.3v
                                4 3.3v
                                5 3.3v
                                6 3.3v
                                7 3.3v
                                8 0v
                                Battery and Charger
                                1 0v
                                2 0v
                                3 3.3v
                                4 3.3v
                                5 3.3v
                                6 3.3v
                                7 0v
                                8 0v
                                Hmm so far all measurement are correct, and as it should be. Active low battery present signal is OK. Low indicates battery present, high indicates battery absent.
                                It remained only to check the continuity in the PBAT_SMBCLK & PBAT_SMBDAT lines between the battery connector and the KBC chip (see the attached image).
                                Is the additional daughter board (suspected to be defective one) being connected to the main board when taking all the measurements? Because the signal PBAT_PRES# goes through JIO2 and that connector is on the additional suspected defective board. So given the fact that all measurements so far are OK, and the battery is confirmed good, maybe that's where the problem is. It is best in this case for you to try and see if the problem persist with a known good working daughter board.
                                • Andreasbest
                                  • Aug 2014
                                  • 1180
                                  • Hellas ( Greece )
                                  With or without the defective board the battery status on BIOS goes from "Charging" to "Discharging" repeatedly.
                                  Like disconnecting and connecting the charger again and again.
                                  I don't see the "communication error" message anymore.
                                  Laptop works without interruption with charger only just the charge has issue (tested both batteries, one Dell and one OEM)
                                  Voltages on PR3 with charger, battery and defective board connected are:
                                  1 0v
                                  2 0v
                                  3 3.3v
                                  4 3.3v
                                  5 3.3v
                                  6 3.3v
                                  7 0v
                                  8 0v
                                  • Andreasbest
                                    • Aug 2014
                                    • 1180
                                    • Hellas ( Greece )
                                    Update:
                                    Laptop doesn't power on with battery only, if i attach charger it works and then if i remove it it keeps working with battery like it should.
                                    Really weird situation.
                                      • 21381
                                      ok. have you checked PD702,PU1001 and all around the dock connector for liquid damage/corrosion
                                      • Andreasbest
                                        • Aug 2014
                                        • 1180
                                        • Hellas ( Greece )
                                        I can see corrosion on several solder points (lead turn black) but nothing major.
                                        All MB is good and clean, probably something is corroded but i can't see it.
                                        • Stephen
                                          A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                          by Stephen
                                          Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                          05-29-2025, 10:35 AM
                                        • ravi_1617
                                          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                          by ravi_1617
                                          Hello to all ,
                                          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                          on external VGA port image is perfect /normal , Attached image...
                                          07-25-2025, 12:07 AM
                                          DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Precision 5820 Precision 5000 W-2235 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
