MacBook Air 820-3437B ALL_SYS_PWRGD Missing
  • ACS-Repair
    • Feb 2021
    • 204
    I have this MacBook Air 820-3437-B that came back several months after cleaning up some corrosion around the ALL_SYS_PWRGD area. Last time this was all that was missing and it required a couple of jumpers to restore the signal.
    This time the computer will not come to S0 state. ALL_SYS_PWRGD is missing at U1950, and so is PP3V3_S0, and so PM_PCH_SYS_PWROK. PM_SLP_S4_L is also at 0v. I've looked this board over carefully and I believe that I have found and corrected all of the corrosion.
    It begins to be a chicken and egg when trying to follow the loops for these signals. It's hard to say which one is affecting the other. I'm sure there is a priority list somewhere.
    This is what I have:
    PPBUS_G3H = 8.6v
    PP3V42_G3H = 3.42v
    PP3V3_S5 = 3.3v
    SMC_RESET_L = 3.4v
    PM_SLP_S3_L 0 0v
    PM_SLP_S4_L = 0v
    PP1V05_S0 = 0v
    P1V8S_S3 = 0v
    P5VS4RS3_EN - 0v
    P1V05_S0 - 0v
    PP1V2_S3 - 0v
    PP3V3_S0 - 0v
    PP1V5_S0 - 0v
    PP5V_S0 - 0V
    At the PCH, I have the following:
    PCH_SUSACK_L = 3.3v
    PM_SYSRST_L = 0v
    PM_PCH_SYS_PWROK = 0v
    PM_PCH_PWROK = 0v
    PM_RSMRST_L = 3.3v
    PM_PWRBTN_L = 3.4v
    SMC_ADAPTER_EN = 3.4
    PM_BATLOW_L = 3.3
    I would appreciate it if someone could show me where to start.
  • mon2
    • 14154
    Re: MacBook Air 820-3437B ALL_SYS_PWRGD Missing
    https://www.it-tech.com.au/mac-q-a/pm-slp-s4-l-timing/
    • ACS-Repair
      • Feb 2021
      • 204
      Perfect, thank you!! I'll let you know how I make out.
      • ACS-Repair
        • Feb 2021
        • 204
        So, I checked the 11 signals from the list in the link and found this...
        1. PPVRTC_G3H 3.3v (3.3v)
        2. RTC_RESET_L 3.3v (3.3v)
        3. PCH_SRTCRST_L 3.3v (3.3v)
        4. PCH_INTVRMEN_L 2.84v (3.3v)
        5. PCH_DSWVRMEN_L 2.83v (3.3v)
        6. SYSCLK_CLK32K_RTCX1 32kHz (32kHz)
        7. PP3V3_S5 3.3v (3.3v)
        8. PM_DSW_PWRGD 3.4v (3.3v)
        9. PP3V3_SUS 3.3v (3.3v)
        10. PM_BATLOW_L 3.3v (3.3v)
        11. PM_RSMRST_L 3.3v (3.3v)
        +1. PM_PWRBTN_L 3.3v (3.3v)
        PPVRTC_G3H 3.3V (3.3v)
        According to this checklist I should have PM_SLP_S4_L to enable my main voltage rails and ALL_SYS_PWRGD. unfortunately this is not the case. The only deviation is that PCH_INTVRMEN_L and PCH_DSWVRMEN_L is lower than expected. While not correct it shouldn't make a difference.
        I'll need to keep looking...
        • mon2
          • 14154
          See if you can do a smc bypass:
          https://boards.rossmanngroup.com/thr...lp_s4_l.53151/
          • ACS-Repair
            • Feb 2021
            • 204
            Thanks mon2. I did an SMC bypass and found a 1/2 second fan spin after about 4 seconds. After that, nothing. I must have another corroded trace somewhere and I'll need to look them all up (the 11 on the list) to make sure that they are getting to where they need to go.
            • piernov
              • Jan 2016
              • 4435
              • France
              https://logi.wiki/index.php/User:Pie....2C_what_do.3F
              • ACS-Repair
                • Feb 2021
                • 204
                Thank you for that piernov, it was a big help. While I did find that all of the points in the Wiki referred to were good, it did point me to corrosion on one of the pads for C1910 (PPVRTC_G3H). I removed the capacitor, cleaned the pads, and replaced it. Doing this has made a difference because I'm now seeing pulsing voltages on PP5V4_RS3 (L7520) and PP3V3_S5 (L7560). I believe that PP3V3_S5 was solid before and PP5V4_RS3 was not present. PM_SLP_S4_L is now pulsing, where it was not present previously. Lots of EN are now pulsing... This may have been a step back so I'll need to backtrack to see why this happened.
                • ACS-Repair
                  • Feb 2021
                  • 204
                  It appears to be a short on the PP5V_S3 line (L7520). Not sure where that came from but I can see all of the main rails pulsing like a heartbeat. I don't remember touching anything that had to do with the 5v supply but that's the next focus.
                  • ACS-Repair
                    • Feb 2021
                    • 204
                    So that one was on me. I inadvertantly swapped the DC-IN board and had a 2012 one connected, which is no good. So I'm back to where I was. Changing the capacitor hasn't made any difference but it needed to be done.
                    • Adogabriel100
                      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                      by Adogabriel100
                      Hey! This is a A1278 macbook 2011.
                      Problem: Not turning on / No green light
                      Im using by3200s charger.
                      Voltajes:
                      PPBUS_G3H = 12.26v
                      SMC_RESET_L = 3.3v
                      PP3V42_G3H = 3.42v
                      U7000 =
                      Pin 1 CHGR_AGATE = 0v
                      Pin 2 CHRG_DCIN = 19v
                      Pin 3 CHRG_ACIN = 4.6v
                      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                      Pin 12 PP3V42_G3H = 3.42v
                      Pin 13 CHRG_RST_L = 3.3V
                      Pin 14 SMC_BC_ACOK = 0.8V
                      Pin 19 PP5V1_CHRG_VDD = 5.05V
                      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                      04-01-2024, 01:02 PM
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
                    • salopian
                      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                      by salopian
                      Hello. I would need some advice please.
                      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                      I have already replaced the logic board with another...
                      02-27-2021, 07:30 AM
                    • mferna14
                      Apple MacBook A1398 820-00138-A missing 5V
                      by mferna14
                      HI all, I am working on Apple MacBook A1398 logic board # 820-00138-A. The problem is that it does not turn on & no fan spin. Board is very clean & no sign of liquid spill. Upon checking the initial troubleshooting power rails, I found that its missing 5V (Absolute 0V on the Coil L7720, no pulsing at all, it's just 0V). 3.3V is PERFECT & across all points on the logic board. Checked the IC U7501 pin 4, this pin should have the ENABLE volts to turn on the 5v rail, & P5VS4_EN is missing. This signal generated from U8170 pin 4. PM_SLP_S5_L is also not present & ALL_SYS_PWRGD is...
                      01-16-2023, 01:35 PM
                    • _Cupa
                      MacBook Air 2011 13" >820-3023 A< no power (PLT_RESET_L missing)
                      by _Cupa
                      Dear community,
                      this is my very first post, I am quite new to macbook repairs, and I am excited:-)
                      I have a 2011 MacBook Air 13' that does not power on. No fan spin, nothing.
                      Here are the specs:
                      MacBook Air Mid-2011
                      CPU: 1.7 GHz Core i5 (I5-2557M)
                      Model: A1369 (EMC 2469)
                      RAM: 4 GB
                      VRAM: 384 MB
                      The first question:
                      Unfortunately, it came with a 'fake' power adapter which seems not to talk to the computer. Sometimes it does show green light immediately after connecting it to the board,...
                      04-01-2021, 02:01 PM
