eg 530 nm-b671 rev 1.0
  • Antonynl
    • Apr 2021
    • 74
    • Nederland
    I do have 3.3 and 5v low power near PU402 (on 2 condensators below coil PL402) but no 3.3v on 32 pin JKB1 connector. Keyboard has built in power switch, motherboard doesn't power on.
    I also just posted a request for schematics
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: eg 530 nm-b671 rev 1.0
    Check whether you have voltage on NBSWON#/DNBSWON# pins of sio.
    • Antonynl
      • Apr 2021
      • 74
      • Nederland
      I don't have a schematic unfortunately
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You can look up the SIO pins from another schematic with same SIO. You have the mb in your hand. Why not read the sio number and find out another schematic with same sio?? Remember, you cant get schematic for each and every mb-so need to struggle a *******nt give up when i know you can.
        • karlox
          Lenovo LA-H103P A little help please!
          by karlox
          Hello! I have this card in the workshop with startup issues. The equipment arrived dead. I replaced a coil and IC RTS5448, and now the equipment is turning on with low consumption at 0.04A at 20v. I don't have the complete startup sequence; I suspect there might be a short or damaged component that I can't find. I took measurements on IC PU402, and they seem correct. The coils PL404 have 5V, PL402 has 3.3V, PZZ1, and PLZ2 have 001.0 mV, PL301 has 1.3V, and PL502 has 020.0 mV, In PLG1, I have 073.0 mV, and in PQ313, I have 5-8 19v and 1-3 1.3v. Thank you. Any ideas are appreciated. By the way,...
          03-26-2024, 07:22 PM
        • ruletero
          Lenovo G40-30 no display NM-A311
          by ruletero
          Please help to fix this Laptop
          brand: Lenovo G40-30
          MB model: NM-A311
          Trouble: turn on without video, it consumes 100 mA only
          It has all voltages:
          COIL Signal Value (volts)
          PL401 +3VALW 3.36
          PL402 +5VALW 4.98
          PL902 +CPU_CORE 0.9
          PL901 +GFX_CORE 0.78
          PL601 +1.8VALW 1.78
          PL701 +1.0VALW 1.01
          PL501 +1.35V 1.36
          PJ504 +0.675VSP 0.67
          Too has these voltages:
          PMC_PLTRST#= 1.8v
          PLT_RST# = 3v
          PCH_LCD_VDDEN_Q = 0v ???
          And it...
          05-06-2021, 11:29 AM
        • mauda
          Lenovo G50-30 (LA-B102P) no POST when power on
          by mauda
          Hello, I have a problem with a Lenovo G50-30, motherboard LA-B102P Rev: 1.0, ZIWBO/B1/E0, 2014-06-12
          Motherboard powers on (power LED is OK), but no POST, no video (internal or external), no beep, no Caps lock LED indication, nothing.
          It is not a "no backlight" scenario - there is nothing on the screen.
          Pressing the power button for several seconds turns the motherboard off. So at least that logic is working.
          I tried known good compatible DDR3L RAM
          All power rails seem to be OK:
          PL_coil = stand_by voltage, power_on voltage
          02-02-2021, 01:26 AM
        • kalilinux25
          LENOVO Shorted +5VALW AND +3VALW LINE ACLU9/ACLU0 NM-A311
          by kalilinux25
          Hi good day to all hope someone can give me some advice whats happening to this board.
          Ive check the output voltage line of +5valw and +3valw all shorted I thought I was having a SIO shorted to.
          I try to remove the SIO chip But still shorted I tried to check all CAPS of the pu401 and PU402 all ok
          SHORTED TO GROUND
          PL402 AND PL401 , i tried also to remove the 2 coils and test the PJ402 and PJ406 im having short at those sections,
          I hope someone can guide me if anyone, Thank You in advance...
          01-20-2021, 11:56 PM
        • master3112
          Lenovo T480 NM-B501 no picture
          by master3112
          I have a T480. After pressing the power button, the device boots up. I can hear the Windows welcome melody. However, the screen remains black.
          The device has a CPU with an integrated GPU. If the device is switched on briefly without the CPU cooler, only the CPU core area heats up under the thermal camera. I measured the PU402 and PU403 inductors. These are responsible for the core voltage. I have 1.1V at these. Everything is OK, therefore the device starts up.
          But I have 0V at the PU404 inductor, which is responsible for the GPU voltage. The power management of the CPU is solved using...
          03-04-2025, 04:19 PM
