Strange problem and solution (BIOS - Bad Caps)
  • mecmast
    • Jun 2021
    • 15
    • Cyprus
    I was working on a laptop motherboard, all the caps (including polarized ones), resistors and some of the inductors were shorting the ground.
    I've tried many things, changing MOSFETs, caps, etc.. but nothing did solve the problem.
    After re-programming a new bios made the trick and the laptop works perfect now.
    I'd like to ask if the problem, shorting to ground, was because of bad BIOS? This is the first time i see a lot of shorts.
  • Hexel
    • Jan 2019
    • 15
    • Ukraine
    Re: Strange problem and solution (BIOS - Bad Caps)
    Do you have exact reading of resistances, before reflashing?
    If you rely on multimeter measure "beeping"/"not beeping" it is correct only for electricians working on house wiring.
    Just after de-energizing, switching voltage regulators goes into Output discharge mode, when output is formely shorted to ground. It may be your case, but I not sure about correlation with old/new dump.
    • mecmast
      • Jun 2021
      • 15
      • Cyprus
      Resistances: No reading or wrong readings.
      I've measured'em all.
      After the BIOS no short readings as beeping like electricians working on house wiring.
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
        I'm trying to reset my bios without success.
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
      • trouble55
        NEC VersaPro PC-VRT42FBFR22B BIOS problem
        by trouble55
        Hi All,
        [Mother board model]
        V-VE212(U3E1)
        [Serial number]
        24000135PA
        [BIOS chip model]
        Macronix MX77L12850F
        I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
        I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
        I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
        09-19-2024, 01:24 AM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
