AHL50 / ABL52 LA-C701P REV 1.0 runs on battery only
  • Ns77510008
    • Mar 2020
    • 51
    • Moldova
    Hello everyone. tell me my laptop only runs on battery power. When I connect the power, it does not turn on, but on the lab unit I see that it is charging the battery
  • mon2
    • 14009
    Re: AHL50 / ABL52 LA-C701P REV 1.0 runs on battery only
    https://www.badcaps.net/forum/showthread.php?t=90356
    Likely you have a shorted mosfet but each stage starting from the dcin connector needs to be reviewed.
    Post clear pictures of the internal logic board starting from the dcin connector.
    Do you have test equipment and hot air soldering tools?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mzk10k
      AHL50/abl52 LAC710p - ac120ns no power with battery connected
      by mzk10k
      Hello
      I have model AHL50/abl52 LAC710p - ac120ns. It doesn't turn on after connecting the battery. The battery is charging correctly. I remove the battery, restart the bios by pressing the start button for 30 seconds without a charger and it works. I connect the battery, press the start button and it does nothing.
      When it is on and I connect the battery, I reset it and it works and detects the battery.
      I have measured some voltages according to the schematic and they are correct.​
      Can the BIOS be corrupted?...
      05-31-2024, 11:37 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
