Lenovo 700-15ISK-80RU - Standby voltage missing
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    In Short: the laptop was flooded with water 3-4 years ago, but after service cleaning was working fine, except battery wont charge on it. After years, a month ago, laptop just shutdown itself and never power on.
    After first board review, the short circuit was found. The capacitor died and burned pad. The temperature was so high that the two layers of textolite were burned. Good news that the layers was GND, so nothing critical. The burned fragment was cleaned and the short gone. Replaced them, but no standby voltage. When plugin DC, the 3.3v and 5v comes on but on one second and then off. the 19.9v are onboard.
    Adding schematic, boardview, scanview at zips
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo 700-15ISK-80RU - Standby voltage missing
    Its normal for 5VALW and 3VALW to appear for a second and off 'coz of DEEP SLEEP WELL(DSW) feature on newer boards. Notice your dc supply consumption- it may start with 10-20mA and drop to 01-03mA once it goes to deep sleep. When you trigger, it will first come up from deep sleep stage to S5(that's when you will once again get voltage on 3/5V ALW coils) and then moves up the power sequence. So your problem may be elsewhere.
    • EdwardGeo
      • Mar 2020
      • 109
      • Ukraine
      Thanks for replying!
      I done force applying 5v on usb/hdd line and the board becomes really hot in the location of up4501 (can't remember the label). That ic responsible for generation main voltages: 3.3v, 5v.
      Almost forgot: the power button reacting on power on, but only on one second. So I think the best way to replace that IC and power controller, as it looking like after hard times.
      The main question: why so many capacitors were died... because of corrosion or high pulsating on pwm controller?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Check if PCH is alive or not after removing 3/5V pwm controller. Its not safe to inject 5v there as it has SOC architecture.
        • EdwardGeo
          • Mar 2020
          • 109
          • Ukraine
          I've done replaced dead mossfets and pwm, but they died after few seconds of power on. So get to the beginning.
          Also found more new dead mossfets. The 5v again is grounded...it could be a lot more defective components that I have imagined...
          Need to desolder all capacitors.
          • FrozenHaxor
            • Jun 2015
            • 260
            • Poland
            No need at all. Remove the 5V coil and inject a maximum of 3,3V on the load side, check for what's getting hot and investigate.
            • EdwardGeo
              • Mar 2020
              • 109
              • Ukraine
              Found some few dead capacitors, but that is not solved 5v.
              The last who could possibly use 5v is pch or Embedded controller?
              Will test with 3.3 with limit of 100 mah.
              Also I saw that gpu oscillator is cracked.
              The other could be possibly dead is cpu. mosfets on 20v to 1.2v has resistance of 40 ohms, but shouldn't have it. But maybe need to look at datasheet of them
              • FrozenHaxor
                • Jun 2015
                • 260
                • Poland
                That's not nearly enough. Limit the current to 5A. Point of 3.3V is to avoid overvolting another rail in case there is an internal component short that has two rails in contact. I've seen it happen. Sometimes even starting with 1.5V is a good idea if you're uncertain and the board is badly damaged.
                You'll never heat the short with just 0.1A enough to detect it, most of it is being lost in power supply leads anyway unless you use thick copper wiring.
                Define dead, were they shorted out? Which capacitors were they? Please post a picture. That's very unusual to have more than 1 damaged capacitor on those boards.
                • EdwardGeo
                  • Mar 2020
                  • 109
                  • Ukraine
                  Added images. The first HiQ scan at first post.
                  Red - mean dead.
                  The story of board is sad: it was flooded with wine, after few years was extremely overheat (the isolation plastic is heat deformed) and the last is short and burn of layers
                  • FrozenHaxor
                    • Jun 2015
                    • 260
                    • Poland
                    Is the carbonized laminate section scorched down to deeper PCB layers? Dig that black stuff a bit, it could be a multi layer short, doesn't look good. I've sometimes had to grind out mosfets that were completely welded in.
                    • EdwardGeo
                      • Mar 2020
                      • 109
                      • Ukraine
                      Yeah, three layers. But seems that they were gnd
                      • EdwardGeo
                        • Mar 2020
                        • 109
                        • Ukraine
                        after I have removed all capacitors, Embedded controller, two pwm from 5v, the resistance to ground fall to 50 ohms. All those components were dead. After I add 1.2 v to 5v line with safe overload up to 4.5a, the resistance to ground start dropping to 19 ohms and power supply was automatically poweroff with overload at more than 4.7A.
                        The last one mossfets who are connected to 5v is cpu power rails. If they are dead, then we know the reason. Continue desolder tomorrow. That's very interesting case.
                        If solder new capacitor at 5v it will die immediately.
                        Also ordered replacement motherboard replacement.
                        • EdwardGeo
                          • Mar 2020
                          • 109
                          • Ukraine
                          I think that the reason of that problem is partially dead mossfet that converts 19v to 5v, so 20v jump to those components. But how 35v capacitors died is the question
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            I'll never suggest to inject more then 1V/5A on any rail if mb has SOC to avoid damage to cpu+pch. Injecting 3v or 5v on a shorted rail may kill pch/cpu if you have any leaky/shorted high side mosfet on cpu/gpu area. Sometimes its very difficult to find out what is heating with only 1V/5A injected and that's why i boght another dc supply with 10A capability. It heps when i inject 1V/10A on the shorted rail.
                            • FrozenHaxor
                              • Jun 2015
                              • 260
                              • Poland
                              Yep, that's a very good advice. Also thick cables help quite a bit, otherwise all the current gets lost on the way to the board.
                              I think this board is a complete loss looking at this laminate, especially with layer to layer shorts. Once the FR-4 gets carbonized, the laminate gets permanently conductive in that spot and only gets a lower resistance with time.
                              • EdwardGeo
                                • Mar 2020
                                • 109
                                • Ukraine
                                Finally solve a short on 5v.
                                Now I have 150 ohm resistance to ground and power usage of 75-150 mah. The phase now is stable and even with 5v. I waited for 15 minutes and everything is okay.
                                So need to find out why those pwm, ldo and capacitors died. If their pins have no short, then that motherboard have a chance to be repaired
                                • jaroslav.psenicka
                                  Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                                  by jaroslav.psenicka
                                  I have a Lenovo Yoga 13 Panasonic here, when powered
                                  • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                                  • most voltage rails seem OK (see image below, red labels)
                                  • resistnace to ground mostly seem OK as well (blue labels)
                                  the only suspicious is the 0.0V rail (2nd from left, top row)
                                  • the resistance to ground is rather low (1.9ohm)
                                  • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                                  also tried new BIOS, no change
                                  I can't find a schematics for the board - can some of you gurus look at the voltages?...
                                  05-02-2024, 05:59 AM
                                • platinumsteel
                                  HP 14-dq2088wm 11th Gen Missing 3V/5V Standby Voltage
                                  by platinumsteel
                                  Hi guys have a HP 14 Labtop. DA0PAHMB8F0 .There is no White LED on the DC Jack .It got a drop of water damage right next to the 3V IC ( Silergy SY8386BRHC) and corroded a resistor and a pad which belongs to the Enable for the IC. I cleaned the area and re-soldered the resistor. Nothing Changed. I don't know what the value for the resistor should be.It measures about 80.0K No schematics available for this model. A good friend on here mon2 helped me identify the IC markings and gave good advice on making sure to measure the input voltages and enables and checking for short.
                                  There is no short...
                                  11-12-2024, 05:49 AM
                                • Sportline
                                  Samsung LE32S81B - missing standby voltage
                                  by Sportline
                                  Good day, instead of Q0165R I mistakenly put 24C256 (don't ask me how) and made a short circuit. After I put Q0165R I don't have stand by voltage again. There is no voltage on the cold side. I found the schematic.
                                  I checked a few things but didn't find anything. When I checked the DB802 diode, it showed a short circuit, but when I unsoldered one leg, it looked fine, and I still have a short circuit on its contacts. On the other side of the board, I have DZB801 also shorted, but it is SOT23, so I didn't remove it, do you think it could be connected to it? Could there be some protection...
                                  03-10-2023, 06:38 AM
                                • TecnicaNTT
                                  Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
                                  by TecnicaNTT
                                  I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
                                  My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
                                  I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
                                  I am now asking here for help if anyone knows how to do this in...
                                  09-20-2024, 08:10 AM
                                • rddube
                                  Lenovo L490 Ram voltage circuit malfunction
                                  by rddube
                                  Hello friends,
                                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                  07-15-2025, 04:41 PM
