Are T2 bypassable?
  • orientalsniper
    • Apr 2013
    • 459
    Are T2 bypassable?
    I have yet to work on one, but would like to know before I receive one soon.
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Are T2 bypassable?
    Bypassable, yes, unlockable, no. Yet, atleast..
    • orientalsniper
      • Apr 2013
      • 459
      It relocks back as soon you reinstall OS?
      Do I need anything more than a CH341 programmer for the bypass?
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        As far as I have tested and understood about bypassing T2, it's much much easier, reliable and problem free to just pay 150 USD to checkm8 (they made it possible) for bypassing. In this case, you don't even need to unsolder, program and solder that eeprom.
        And you will get a lifetime of bypassing with that.
        "Free" T203 method relies heavily on checkm8 database and you might be running into problems with that method.
        To bypass, you need another macbook to go into DFU mode and bypass using checkm8.
        • Loli Popu
          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 08:29 AM
        • Sparklingx
          CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
          by Sparklingx
          So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
          So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
          now all...
          08-29-2024, 01:53 PM
        • dellxps15
          macbook air m1 820-02020 cant restore on reinstall osx.
          by dellxps15
          hi all, just got this macbook from a parent. it was previously water spilled. my cousing took it to a repair shop where they cleaned the water spot corrosion and make it boot again, but they were not able to reinstall osx. after that my cousing bring it to me, but im facing same problem. neither in dfu, usb osx installation media , neither internet recovery works.
          in disk utility, it see 245gb ssd, i can inizialize it and start reinstalling osx, but at some point it will give me error. i read somewhere that it could be a bad caps, but all values loks good. i checked also pp5v_s2 coil and...
          08-14-2025, 03:18 AM
        • Peter_1402
          Flashing AM4 BIOS with CH341
          by Peter_1402
          Is it impossible to flash Asus TUF B450M-Plus Gaming BIOS(25LB128D) with CH341? I have done it with H270N BIOS.
          I used NeoProgrammer and selected 25LQ128C IC since 25LB128D is not in the chiplist.dat. I get no response from IC.
          Any expert can help on setting up the import.xml so that I can import 25LB128D into chiplist.dat.
          Thanks in advance.
          07-10-2025, 09:13 AM
        • Sparklingx
          Everyone is buying the wrong CH341 programmer
          by Sparklingx
          Everyone is buying the wrong CH341A programmer, I have learned from my mistake. Don't buy the Black one or Green one.
          Buy this one in the photo. Most stable and all your common problems (reading but not writing/erasing, software hanging, disconnects after attaching chip, test cable connected but chip not found/ device disconnected) will be gone.
          Otherwise you'll have to solder capacitor from GND to VCC if you have those symptoms in your black or green miniprogrammer....
          09-11-2024, 02:03 PM
