Lenovo Z500 LA-9063P no power
  • embcsk
    • Jul 2021
    • 5
    • Philippines
    May I know the values of the following components? Both are shorted.
    P (white component) just after the power supply pins before PF101
    PR302 (white R010)
    Thanks!
    • 21304
    Re: Lenovo Z500 no power
    Whats the motherboard part number, is it LA-9061P or LA-9063P
    • embcsk
      • Jul 2021
      • 5
      • Philippines
      it's LA-9063P
      • embcsk
        • Jul 2021
        • 5
        • Philippines
        will appreciate any help here. thanks
        • Sephir0th
          • Oct 2020
          • 1283
          Show on a Pic for what you're looking.
          FairRepair on YouTube
          • electrocute
            • Mar 2021
            • 23
            • spain
            Re: Lenovo Z500 LA-9063P no power
            Originally posted by embcsk
            PR302 (white R010)
            PR302 = 0.01_1206_1% (power resistor, 0.01 Ω, size:1206)
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Mita99
              Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
              by Mita99
              Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
              Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
              Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
              04-27-2025, 07:20 PM
            • Dr.d
              Help please..Lenovo ideapad 5 14itl05 power and charging problem
              by Dr.d
              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
              04-05-2024, 11:48 AM
