Which Smd component to replace - DAG3JBMB8D0
  • budiex
    • Jul 2021
    • 9
    • Chile
    Hello first of all, data to take into account:
    Motherboard: DAG3JBMB8D0 REV: D
    Computer: HP Pavilion Gaming Laptop - 16-a0006tx
    Diagram/schematic/boardview: I can't find them yet.
    Problem: Computer turns on and shuts down immediately.
    Well, I'm not an expert nor a technician, I just repair things for hobby, some time ago I got a motherboard with its power cable and button.
    I assume that the board had been intervened by a technician, they reprogrammed the E.C. and main bios.
    I made measurements until I got to the E.C. bios that did not receive voltage, I came to the conclusion that it had short components after a visual check millimeter by millimeter, I found that it had 3 missing components.
    this is the best image I got of this plate
    I rebuilt the track in a sector where one component was missing, the other 2 missing components I assumed that I could place the twisted component and it would make the same contact.
    Here come the problems, as I am new to this subject I do not know what components go in those sectors, by the size could be a capacitor or a resistor, I'm just guessing since I have no idea. if someone could give me some help on what component goes in the right place I would appreciate it very much.
    In the images I put numbers and mark the area where the components are missing, I also made measurements ala track where the components were missing as seen in this image:
    thank you very much any kind of help is welcome.
    • 21635
    Re: Which Smd component to replace - DAG3JBMB8D0
    • pereborka
      • Sep 2021
      • Russia
      Hi, budiex! I have such a fee at work and on Monday I can take a photo with measurements of the parameters of the elements in the right place. There are no elements in the IT5570 binding on my board. I hope for reciprocal help in my problem.
      • pereborka
        • Sep 2021
        • Russia
        Hi, budiex! I took a photo of my board and measured the parameters of the elements. Please help me with my problem. Next to IT5570 there are empty areas after the board is filled in. Apparently, the elements in this place have rotted.
        • efrain
          • Oct 2017
          • 12
          • colombia
          Hello friends, i need your help, i need identify the marking ic in the photo, the ref. of the mobo is DAG3JBMB8D0, please help
          thank you
          • romky
            • Nov 2015
            • 9
            • Poland
            Hi, there are 3 lines of text on the chip: MPS2023, MP2949A, M2643188X.
              • 21635
              Monolithic power MP2949A
              • caprigtx
                • Mar 2022
                • 63
                • Netherlands
                Hi There , can some one tell me what component this is?
                dag3jbmb8d0 rev d model g3jb
                • mon2
                  • Dec 2019
                  • 14632
                  https://www.lcsc.com/product-detail/C358653.html
                  https://www.aliexpress.com/w/wholesa...tail.1000002.0
                  • caprigtx
                    • Mar 2022
                    • 63
                    • Netherlands
                    Thank you.
                    • Yolofolkss
                      Huawei D14 dah98ambad0 rev d please help identify Missing components
                      by Yolofolkss
                      Hello I just bought this laptop to be used personally (that I'm currently trying to repair.), I am aware that liquid (gravy) has been spilled in this area before. but there are missing components it it possible to have a board view or a schematic of this? or just an idea on what components its missing?
                      as far as I know this parts are connected as sense or enable.... that's how far I know...
                      Images attached:
                      the picture of the area. and some of the pinouts that I noticed on the chip...
                      03-26-2023, 12:37 AM
                    • Artakozu
                      Xfx RX470 - Missing components
                      by Artakozu
                      Hi, I'm new to this forum.
                      I recently bought a damaged XFX RX470 for around $10-12 USD. As you can probably see, I believe the only issue is some missing components, likely due to a scratch or a fall.
                      Can anyone help me confirm which components are missing, and specifically, tell me the value of capacitor C502?...
                      05-20-2025, 06:26 PM
                    • summerwhite
                      DJI Mini Pro 3 missing components near camera connector
                      by summerwhite
                      I have a DJI drone that is not displaying a video feed anymore after a repair.
                      When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
                      Now there are missing components either because they got pulled off or because they where never placed.
                      I have two reference images from XXZ and a photo of mine.
                      I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
                      On the board view from XXZ they...
                      04-06-2025, 11:15 PM
                    • grimacelord
                      HP 15-cs3055wm - DAG7BLMB8DQ REV:D - Missing Components - Fan Error
                      by grimacelord
                      I have an HP laptop here (model and board model in title) that powers on with an error message about the fan not working properly and needs to shutdown. The thing is, the fan is spinning just fine. I disregarded the message and continued to boot into Windows and loaded up OCCT to look at temperatures and the OCCT was reporting that the CPU was very hot (98C) and climbing, so I shutdown the computer, did a CMOS reset and checked then thermal paste and heatsink for dust build-up. Paste looked good, but I cleaned it off and applied fresh paste anyway and blew out the fan from...
                      03-15-2024, 01:29 PM
                    • Ryan Wurtz
                      DAOPDIMB8GO Rev .G not charging, missing components identification
                      by Ryan Wurtz
                      Missing components on the motherboard.
                      Anybody by chance have the same model and can let me know what they are?
                      Symptoms of the laptop are. Working, booting, seems fine except does not charge. Windows even says it's charging. But does not. Also charging light is on. So I'm guessing Im missing some Resistors
                      Can manually charge the battery.
                      Let me know if you need more pictures or have any questions....
                      09-02-2025, 07:40 PM
