Dell 15-3537 VBW00 LA-9981P SUSB# problem
  • menshawy
    • Aug 2013
    • 400
    • egypt
    hi
    i have a problem with Dell 15-3537
    MB VBW00 LA-9981P
    CPU SR170 -Intel Core i5-4200U
    MB power on OK but not display and fan is not spins
    3valwp,5valwp OK
    rsmrst OK
    3VALW_PCH OK
    all VS volts is absent
    SIO_SLP_S3 and SIO_SLP_S4 is not shorted with GND
    u2301 pins 3,5 SUSB# signal is 0v
    i was programed EC and main BIOS ,change YC1 ,Q8 with no success
    what is SIO and PCH requirements to Generate SUSB#
    I am thinking about reballing cpu but I want to be sure before that
    need help
    thanks
  • mido23
    • Feb 2018
    • 13
    • paris
    Re: Dell 15-3537 VBW00 LA-9981P SUSB# problem
    Hello, check the SYSON signal
    if it is 0V
    Mostly SIO is a problem
    • Techtiger
      • Oct 2014
      • 1602
      • france
      What is the resistance on pin 116 SIO SUSP# ( this platform doesn’t have SUSB#)
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Make sure RTC VCC is clear & PCH_RTCRST# voltage?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          The post is dated feb'21
          • mido23
            • Feb 2018
            • 13
            • paris
            Hello my friends
            Well done brother techtiger
            should be measured rtc vcc before checking SIO SUSP#
            • toti24
              (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
              by toti24
              dell precision m4600 laptop
              i7 2760qm
              8gb ram 750gb HDD
              intel hd 3000 integraded and nvidia quadro 2000m
              pleasea bear with me english isnt my language and ill try to be as clear as possible
              note i live in mexico in a very small town..
              thank you.
              laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
              the brick happened when i was installing win 10 using usb.
              used rufus and officia microsoft.iso
              it finished copying files from usb...
              03-06-2022, 08:39 PM
            • SDNarcia
              Dell 15R-5521 keyboard problem (KBC?)
              by SDNarcia
              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
              As additional information,...
              07-20-2024, 10:47 PM
            • Achille15
              Dell N5110 problem
              by Achille15
              so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
              03-29-2025, 04:41 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
            • MahmoudNasser
              Dell 7480 problem with freezing during the Windows loading process
              by MahmoudNasser
              Hello everyone, I wish you a happy day.
              I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
              Device Data
              Model Dell Latitude 7480
              CPU:i7-7600U
              SN:7T58PL2
              MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
              Bios Chips:W25Q128BV
              The attempts that have been made to solve the problem have not yielded any results.
              1. Changing the M.2 and M.2 Nvme hard drives.
              2. Trying...
              07-09-2023, 05:04 AM
