820-00850 Logic Board 5V, No liquid dmg
  • mgrharry
    • Sep 2016
    • 211
    • usa
    MBP Touchbar, board 820-00850, shut off in the middle of video streaming and never turned back on again. Examined board and USB ports closely and it is clean, no sign of liquid damage.
    USB C meter shows 4.95V, 0mAh draw on all 4 ports.
    PPBUS G3H F7000 = .34v
    PP3v3_g3h = 0V
    PPDCIN_G3H = 5.04V
    PPVIN_G3H_P5VG3S = .34V
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-00850 Logic Board 5V, No liquid dmg
    Fix this.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
    • fajfelek
      Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
      by fajfelek
      Hello, First of all thanks you for reading this topic.
      I need your help with identify missing parts on trackpad logic board (661-18430).
      The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
      Please help me with identity parts from blue and red area .
      06-15-2024, 01:41 PM
