cpu/gpu capacitor short check with power supply possible?
  • darkness77
    • 10
    • Craotia
    Hello, when vcore or gpucore is shorted to ground mostly it is because of dead chip...but sometimes it is dead capacitor.
    Is there any way with power supply to force that capacitor to heat? If i use one volt and one amper on power supply i believe thats too low for anything to heat...but increasing voltage or ampers i risk to burn a good cpu or gpu..
    Any suggestions to noob?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: cpu/gpu capacitor short check with power supply possible?
    Use a thermal camera if you can't feel anything warming up.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3610
      • slovakia
      u must have PSU with high amperage to set 1V and 20A, because cpu and gpu chips have high temp dissipation. 1V 1A makes 1W which is nothing even for little capacitor
      have tons of this intel crap faulty cpu
      • darkness77
        • 10
        • Craotia
        Thank you! So, you are saying its safe to increase ampers without destroying cpu? But voltage set to 1v max?
        In short, i set max voltage to 1v, and increase amps from 1A to 20A (increase it by 1A) till i fill something warming up?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          Current cannot damage good part if u have right voltage. Part take only as much current as tey need. Damaged part have low resistance that take as much current as its resistance. 1V x 20A = 20w which is enouht to see/pour Ipa and look for evaporation/ what part is bad.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            @KTMMOTOCROSS ,Can you suggest a good dc supply with 20A. I have max 10A. Will invest if its good.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • chth96
              What capacitor should I purchase for Power Supply of obsolete game consoles?
              by chth96
              hello.
              I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
              It hardly ever freezed after I finished to recap all of caps in the power supply.
              But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
              To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
              It seems that quality...
              10-01-2024, 08:14 AM
              DVR camera recorder switching power supply capacitor failure really
              These cheap non brand capacitors at it again
              Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
              Well at least I have the cameras back on line I to try the...
              01-22-2022, 06:28 PM
              07-01-2024, 06:34 AM
            • r2digital
              klipsch kda-500 amplifier suitable power supply capacitor replacement ?
              by r2digital
              I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
              04-18-2024, 03:50 PM
