Dell 5565 Not Booting Windows Installer
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. I have a Dell 5565 with a few symptoms, one of wich is that it will not boot into windows 10 install usb. It will show the windows logo for about 1 second, then reboot itself. It does this with and without a hdd or ssd connected. I have tried multiple known working windows install usbs.
    I also noticed that the ram slot A does not work at all. Only ram slot B. I have tested various ram modules and all do the exact same thing (not work in A, and in B never enter the windows installation.
    I have tried to use the f12 menu to update bios (just in case), but it ends up saying that the update file is incorrect (seems to be a common issue with dell).
    I have run memtest86 and it doesn't find any issue, but I am convinced it must be a ram issue, either with the connection or the cpu (it has an amd a9 bga cpu).
    There is no obvious damage to the ram slots or the motherboard. The owner says one day it just wouldn't boot, he decided to swap his hdd to a ssd thinking his hdd had gone bad, but could never get the windows installer to boot.
    Any ideas what to check?
  • petehall347
    • Jan 2015
    • 4434
    Re: Dell 5565 Not Booting Windows Installer
    will it boot live linux ?
    • liquidzorch
      • Oct 2016
      • 135
      • mexico
      I just checked a live windows 10 (hiren's) usb, and it booted. I don't have any linux right now. Weird, why wouldn't the windows installer boot. I just used it on another computer and it works. On this computer it just gives me the logo then restarts.
      • petehall347
        • Jan 2015
        • 4434
        that is a bit strange
        maybe something needs changing in bios settings ?
        there should be tools on hirens cd to check the hard drive
        • liquidzorch
          • Oct 2016
          • 135
          • mexico
          The ssd is brand new. The bios setting have been restored to default. And I started the windows installation from hirens live windows, and it starts copying files, but once it gets to the restart point, it does the same thing, boot up to the windows logo and restart or freeze. I have had the screen get static on the windows logo also. Only when entering the windows setup. I can boot the live version just fine.
          • liquidzorch
            • Oct 2016
            • 135
            • mexico
            Seems to have been a corrupt bios issue. I was able to flash a bios update from the live windows usb. After the update, I was able to get the windows installer up, and install Windows. Now the only issue is, it seems to have lost it's original product key (embedded in bios). Windows does not detect any key. I am guessing there is no recovering the key, right?
            • liquidzorch
              • Oct 2016
              • 135
              • mexico
              Never mind, the key was not found during install, but the digital license was found once online.
              • petehall347
                • Jan 2015
                • 4434
                nice job well done
                • reamon
                  Dell latitude 5310 windows autopilot Latitude 5310 Northbay_MLK_non-TBT MB 10L 19842-1
                  by reamon
                  03-27-2024, 02:32 PM
                  I have laptops with problem windows autopilot does anyone know how to solve this problem
                  I can install Windows if I indicate that I do not have the opportunity to connect to the Internet. But I would like to remove it completely Dell latitude 5310
                  Dell latitude 5310
                  motherboard Northbay_MLK_non-TBT MB 10L 19842-1
                  service tag BYVW963...
                  04-03-2024, 07:29 AM
                • Daniel Kubica
                  Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                  by Daniel Kubica
                  I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                  I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                  06-14-2025, 09:24 AM
                • mferna14
                  ACER Aspire A515-54-74LM not booting in Windows
                  by mferna14
                  I am working on ACER Aspire A515-54-74LM Serial # NXHNAAA00693913C647600 (SNID: 93908099676 ). Motherboard DA0ZAWMB8G0 Rev.G (UMA, no video chip on this board). It turns on fine but when booting to Windows 11, it just keep loading. The Windows ring is continously spinning & does not proceed anywhere. I tried with another known good SSD Card with 100% Windows 11 bootable from this SSD., & result if still the same. BIOS ME Region has been cleaned, same result with old & new BIOS bin files. No Liquid spill anywhere on the main motherboard or the SSD Connector. What is the next step I...
                  05-07-2024, 12:34 PM
                • MahmoudNasser
                  Dell 7480 problem with freezing during the Windows loading process
                  by MahmoudNasser
                  Hello everyone, I wish you a happy day.
                  I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
                  Device Data
                  Model Dell Latitude 7480
                  CPU:i7-7600U
                  SN:7T58PL2
                  MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
                  Bios Chips:W25Q128BV
                  The attempts that have been made to solve the problem have not yielded any results.
                  1. Changing the M.2 and M.2 Nvme hard drives.
                  2. Trying...
                  07-09-2023, 05:04 AM
                  DELL Inspiron 5565 Notebook 5000 Specification for Upgrade or Repair
                  This specification for the DELL Inspiron 5565 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5565 boardview and 5565 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5565...
                  09-06-2024, 07:10 AM
