A2251 820-01949 2020 Macbook Pro Stuck at 5V 13mA
  • KappaDev
    • Feb 2019
    • 41
    I have a A2251 board number 820-01949 which is in a 13" 2020 Macbook Pro and does not turn on.
    Attempted DFU mode incase of corrupted T2, but never gets detected on second machine.
    USB-C ampmeter shows drawing 13mA at 5.22V stable, never switches to 20V.
    Checked and don't see any shorts on caps near CD3217 chips.
    Schematics and boardview appear unavailable
    Any ideas?
  • mon2
    • 13834
    Re: A2251 820-01949 2020 Macbook Pro Stuck at 5V 13mA
    1) How many USB ports on this logic board ?
    2) Power down. Remove battery. For each USB port, check and post the resistance to ground for D+, D- lines.
    3) Any liquid damage ?
    4) The CD3215 / CD3217 are USB Power delivery devices that negotiate with the external power supply. They exchange power contracts and if all goes well, the 20V power rail will be selected. That is not the case for your logic board.
    You can review the similar logic board operation on older models here:
    https://www.logi.wiki/index.php/CD3215_Bootup_Sequence
    It should be helpful.
    Summary: Each and every CD3215/CD3217 must be operational to dial up the desired 20V to power this logic board.
    Post your resistance values.
    • piernov
      • Jan 2016
      • 4435
      • France
      820-00850 schematics/boardview can help.
      PPBUS_G3H?
      • KappaDev
        • Feb 2019
        • 41
        4 USB-C ports on this board.
        Battery removed, powered off. Apologize for ignorance, not sure where to measure D+ and D- from board side of USB-C.
        No visible liquid damage under microscope, both sides of board clean.
        PPBUS_G3H?
        PPBUS_G3H appears missing, measured 0V at both sides of fuse (location similar to that on the 820-00850 board, hoping this is the same rail).
        https://i.imgur.com/NuAaIAa.jpg
        8 Ohms to ground, guess its shorted. Could this be caused by the CD3217?
        • mon2
          • 13834
          Use any passive (has no electronic parts onboard other than the connector) USB Type C breakout board.
          Mate this USB Type C breakout board with the proper Type C to Type C cable (all wires should pass through from A / B side of the cable) - Arrow should have these at fair costs.
          Then attach to your logic board. This is all so you can probe the signals on the Type C connector using the comfort of this breakout board.
          As an example:
          https://www.adafruit.com/product/4090
          but there are many others out there / Amazon / Aliexpress.
          This will allow you to review the status of the CD3215 / CD3217 which may have been nuked by the previous owner during the power delivery contract @ 20V but hitting one of the CCx lines. The new generation of type C ICs offer protection against this event but know from personal experience that I almost burnt my hands with USB PD 1.0 designs a few years ago. Reported the fault to VIA Semiconductor who agreed and revised their silicon.
          TI has devices that protect against this transient event. During removal of a 20V rail the dainty pins slip and short across 5 volt only tolerant pins and often nuke the controller IC.
          Again, this is just a FYI on what may have happened. If you see different resistance readings across the D+ / D- on the port(s) - the one that may appear to be "off the normal resistance" could be a culprit. If one CD321x device is non-working then this will halt the 20V negotiation.
          • piernov
            • Jan 2016
            • 4435
            • France
            No. Few ohms to ground typically means shorted high-side MOSFET to CPU.
            • KappaDev
              • Feb 2019
              • 41
              Understood. Safe to inject 1V under thermal camera inspection?
              • KappaDev
                • Feb 2019
                • 41
                In the event of shorted MOSFET to CPU, should I expect a coil to have similarly low resistance to GND? With battery unplugged and without DCIN, fuse goes to 0Ohms to GND. Haven't injected any voltage in-case MOSFET is to CPU don't want to kill it, but do have thermal camera if needed to take that route. Checked top side coil resistance in image below:
                https://i.imgur.com/ymRyZbn.jpg
                Despite picture, measurements taken without battery connected.
                • NotAFish
                  • Jun 2021
                  Here you go in case you still need it.
                  • mferna14
                    MacBook Pro A2251 820-01949-A stuck on 5V
                    by mferna14
                    Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
                    PPBUS_G3H=12v
                    PP3V3_G3H=3.3v
                    PP3V3_UPC_X_LDO=3.3v
                    PPDCIN_G3H=5v ????
                    PP1V8_SLPS2R=1.8v
                    Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
                    11-08-2024, 05:35 PM
                  • Runnerboys
                    Macbook a2251 Water damage- stuck on Logo
                    by Runnerboys
                    Would appreciate your input, we have fixed a water damage motherboard for the a2251, there was mainly corrosion next to the 2 locations, but were able to clean it all
                    First few times- the Macbook would boot and got to login screen (didn't try to login), day after, when we tested it - it would get stuck on the logo and won't show welcome screen
                    What would be the best step to take from here to test? should I test Mobo components/ chip / storage? and if so- where do I start?
                    OR should I try to use the Apple Configurator and connect...
                    05-17-2023, 11:40 PM
                  • ronelex
                    Macbook Pro A2251 Stuck on 5v
                    by ronelex
                    Hi everyone, I have this unit A2251 820-01949.
                    I receive this unit with a shorted PP3V3_G3H and found the culprit C8161 shorted and I remove it but the unit still stuck at 5v 0.04A
                    This are the readings I got on the unit
                    PPBUS_G3H -12.33v
                    PP1V8_SLPS2R -0v
                    PP3V3_G3H_PMU_VDDMAIN/PP3V3_G3H - 0v
                    P1V8G3S_EN from u7800 - 0v
                    U3100_W
                    PPHV_INT_G3H_W - 5v
                    PP1.5_UPC_LDO_CORE_W - 1.5
                    PP3V3_UPC_W_LDO - 3.3V
                    PP3V3_G3H_RTC - 3.3V
                    U3100_R
                    PP1.5_UPC_LDO_CORE_R - 1.5
                    PP3V3_UPC_R_LDO - 3.3
                    PP3V3_G3H_RTC...
                    12-17-2023, 10:28 AM
                  • Bmet
                    MacBook Pro 13 inch A2238 M2 stuck on 5V
                    by Bmet
                    I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                    04-02-2025, 05:02 PM
                  • Steven Pieter
                    Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                    by Steven Pieter
                    hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                    11-24-2024, 10:02 AM
