820-00165a mac air PPBUS_G3H only 3,4 v
  • myth77
    • Feb 2017
    • 380
    • Croatia
    The macbook air came to me heavily damaged with smashed screen. L7130 was off the board. I cleaned everything, resolder L7130 and when charger plug in i have first green then orange light.
    On PPBUS_G3H i have only 3,4 v (with battery removed)...so here is the first problem...why i dont have 6,8 v? On D7005 PIN 2 and 3 are 14,5v, pin 1 3,4v. I measured short near u7100 but didnt find any on capacitors and resistors. Also short to gnd i didnt find anywhere on the board.
    Ideas?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: 820-00165a mac air PPBUS_G3H only 3,4 v
    https://www.badcaps.net/forum/showthread.php?t=90356
    • PITERPENY
      MACBOOK A1989 820-00850
      by PITERPENY
      Hello. Need a fresh look. MacBook shows no signs of life.
      When connected to USB-C with the battery connected, the consumption is 20V/0.220A and PPBUSG3H=11V.
      If you disconnect the battery, the consumption will be 5V/0.220A and PPBUSG3H=12.3V
      PP3V3_G3H=3.3V
      PP5V_G3S=0V
      PP1V8_SLPS2R =1.8v =0v=1.8v =... cyclically
      voltage around u7800 appears/disappears cyclically.
      06-16-2025, 08:59 AM
    • Joztu
      MacBook Air 13” A1466 820-3437
      by Joztu
      Hello house, please I need help with a MacBook Air 2013 13inches
      Board number: A1466 820-3437
      came in dead, no green light on charger
      ppbusg3h reads 8.18v
      PP3V42_G3H reads 3.4v
      Noticed corrosion on the board which I cleaned and ppbusg3h went back to 8.54v and green light came on from charger
      Disconnected charger to put the board back in its housing and green light wasn't coming on anymore, checked ppbusg3h and it now reads 8.18v as it was before
      How do I proceed cos I'm guessing there's probably...
      06-13-2023, 06:26 AM
    • redbaron1007
      Liquid damaged macbook A1466 fan spins, but doesn't turn on.
      by redbaron1007
      I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
      10-24-2024, 05:45 PM
    • ahoonid
      820-00165 Random green light on charger
      by ahoonid
      Hey everyone,
      I have a MacBook Air 2017 with a weird problem. The MacBook was totally dead at first and the culprit was the C7430 capacitor which was obvious upon initial inspection as it had a fracture on its surface.
      The F7140 fuse was also blown so I changed them both. L7130 due to corrosion was also replaced. Now everything works again. Laptops turns on and everything seems reliable at this point.
      The only issue that I'm afraid might bite me in the ass later is the magsafe light as it randomly changes light from orange to green while charging. Other times...
      04-10-2024, 04:06 PM
    • kingjafad
      Macbook Air 2017 A1466 820-00165 board no power
      by kingjafad
      Hello all,
      A friend asked me to look at her macbook after she 'smelt burning' and it turned off. She tells me they spilt coffee approx 6 months ago on it but it only popped a few days ago. I took the back off to have a look and there is clear sign of liquid damage and a smoking gun area around Q7155 (see attachments). I cleaned the area up a bit with IPA and it doesnt look as bad as i first thought. The other components around there still actually look intact - I realise that is likely just superficial. I took some measurements and there are a lot of shorts to ground, but fingers crossed...
      02-27-2021, 09:58 AM
