820-00165 Random green light on charger
  • ahoonid
    CapsLOCK
    • Jun 2023
    • 52
    Hey everyone,
    I have a MacBook Air 2017 with a weird problem. The MacBook was totally dead at first and the culprit was the C7430 capacitor which was obvious upon initial inspection as it had a fracture on its surface.
    The F7140 fuse was also blown so I changed them both. L7130 due to corrosion was also replaced. Now everything works again. Laptops turns on and everything seems reliable at this point.
    The only issue that I'm afraid might bite me in the ass later is the magsafe light as it randomly changes light from orange to green while charging. Other times it completely turns off while still drawing power around 45mA but of course doesn't charge anymore. In this state when I put it under load it draws the normal 2 to 3A but no light yet again.
    I couldn't find a pattern since the issue happens with or without load. The IO board and cable were also replaced with no change.
    I'm just hoping it's not the SMC.
    Appreciating any helps in advance.
    Cheers.
  • mon2
    • 14758
    Check and/or clean the pogo pin mating contacts with a cotton swab and ipa (alcohol). Be sure the contacts are clean and shiny without any dirt or cat hair, etc.
    Be sure the 3v42 rail is stable. Confirm the operation of the dual common cathode diode that powers the 3v42 regulator. It is a common failure point on this model. This rail is required to light up the MagSafe led head.
    • ahoonid
      CapsLOCK
      • Jun 2023
      • 52
      Thanks Mo2 for your suggestions and help.
      The charger's pins are fine. It's connected to my power adapter and the issue is with this laptop only.
      The 3v42 line seems stable. Even when the charger light is off sometimes, I still have the line with correct voltage! By the mentioned diod you mean D7005? That's not showing any abnormal behavior either.
      Could this be a CMS issue at all?
      • mon2
        • 14758
        Review this thread:
        https://boards.rossmanngroup.com/thr...-to-o-s.48239/
        • ahoonid
          CapsLOCK
          • Jun 2023
          • 52
          I've already come across that thread and I believe it's not the same as my issue. I've already swapped the IO board and its cable with no change. Could there be a small short somewhere? If yes, where would you believe I should check for it?
          I just find it weird how the charger is still drawing power when the magsafe light is off and the system works as expected and normal. Somewhere along the way the battery stops charging and starts charging again! But I can't figure out where.
          Thanks again Mon2.
          • mon2
            • 14758
            How old is the battery? How many charge cycles? Test with another battery. Amazon is good for quick sourcing and can be returned if not required.
            • ahoonid
              CapsLOCK
              • Jun 2023
              • 52
              I suspected the battery and have tried another one with the same behavior unfortunately.
              • ahoonid
                CapsLOCK
                • Jun 2023
                • 52
                Original battery has around 800 cycles and yeah probably not much left of its life. But the other battery whicharound 500 and doesn't show this weird behavior behavior on its own device.
                • mon2
                  • 14758
                  The 500 charge cycle battery also shows the strange behavior on this box but ok on another?
                  • ahoonid
                    CapsLOCK
                    • Jun 2023
                    • 52
                    Precisely.
                    • mon2
                      • 14758
                      Remove all power. Meter in resistance mode. Measure the resistance from pins # 17 and # 18 of U7100. Measure directly at the charger IC U7100.
                      • ahoonid
                        CapsLOCK
                        • Jun 2023
                        • 52
                        Pin #17: 3 not giving me a number! Ranges from 3 kOhm to 40 kOhm and going up. Sometimes around 100.
                        Pin #18: Gives a number. Most of the times 107 kOhm.
                        • mon2
                          • 14758
                          To clarify, place one meter probe on pin # 17, other meter probe on pin # 18. We are wanting to confirm the full path resistance of this current sense loop.
                          • ahoonid
                            CapsLOCK
                            • Jun 2023
                            • 52
                            Ahh ok I thought you wanted resistance to ground.
                            53 kOhm is what I get then. Really hard probing tho as the pins were by each other and very small 😁
                            • mon2
                              • 14758
                              Ok. These measurements are way off from the required resistor values. Proceed now to measure the resistance across:
                              R7151 ; should be ~2 ohms
                              R7152 ; should be ~0 ohms
                              One meter probe on one side of the resistor; other probe on the other side of the resistor.
                              With the 53k ohm resistance, the root cause is here. The charger IC is measuring the voltage that enters the battery charge rail and the voltage that leaves the same rail. From the voltage drop across the current sense resistor @ R7150, the charger IC can calculate the current draw. That is, it can determine if the load is consuming the proper amount of current.
                              With a massive load like 53k ohms, this is way too high and the charger IC is shutting down the charging of the target battery.
                              • ahoonid
                                CapsLOCK
                                • Jun 2023
                                • 52
                                I'm getting 2 and 0 ohms as you mentioned. At this point should I go ahead and replace U7100?
                                • mon2
                                  • 14758
                                  Not yet. Review Q7180 which is often a root cause of these issues. Carefully, measure the voltage to ground of pins 1 or 2 to ground. Check pins 4 or 5 to ground. Post each measurement.
                                  Reference:
                                  Magsafe Sleep Mode - LogiWiki
                                  • ahoonid
                                    CapsLOCK
                                    • Jun 2023
                                    • 52
                                    This might be a very stupid question but the q7180 mosfet only has 4 pins as far as I see but the board view shows pin 1 to 6 under it! How does that work? 😅
                                    I'm getting 20v throughout the mosfet with my psu connected, and 15v when connecting original 45w magsafe which are normal I suppose.
                                    • ahoonid
                                      CapsLOCK
                                      • Jun 2023
                                      • 52
                                      I read the reference logiwiki and compared the behavior of an original magsafe against my psu. With the original magsafe connected to the bare bone MLB, I get random turning off of the orange light and turning back on, and the fan starts to spin at high speed.
                                      with the psu however, the charger is green then orange then green and this goes on until the light is off and shortly turning back on. Sometimes it draws power and the fans are on but most of the times it's not drawing any power when the psu is connected to bare bone MLB. When everything is connected, specially the battery, the psu draws more power and charges as explained before.
                                      • reformatt
                                        • Feb 2020
                                        • 1541
                                        Connections to Q7180 are under the MOSFET itself.
                                        Genuine Magsafe adaptors have a load detection before turning on the full voltage. Knock off's don't do that and apply the full voltage regardless (hence you get sparks sometimes when connecting them). BTW, this detection is within the magsafe connector not the actual power brick. To check this is working right, connect only the battery, and check voltage on R7012. Anything above 0V, then battery voltage is leaking back through Q7180, or in some cases via a leaky D7005. I've also had a corroded R7180 cause similar issues as well.
                                        SMC controls battery charging, so if a valid Magsafe isn't detected, then battery charging is disabled. Pertinent signals are SM_BC_ACOK and SYS_ONEWIRE. The circuitry for the one wire circuit is contained in the LIO board, but you can refer to the older A1278 820-3115 schematics for how it works. SM_BC_ACOK must be high in order to provide power to the IC for SYS_ONEWIRE. The one wire circuit is how the SMC determines the wattage of the adaptor so it needs to be functional for correct operation.
                                        • vdrokko99
                                          MBP wont turn on Only green light on charger
                                          by vdrokko99
                                          I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                          SMBUS_SMC_BSA_SCL 3.5V
                                          SMBUS_SMC_BSA_SDA 3.5V
                                          12-01-2024, 12:18 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • mcnamj70
                                          820-00165 no green light on the charger and no fan spin
                                          by mcnamj70
                                          I am troubleshooting a Macbook Air and the SMC posts a voltage of 8.2V at PPBUS_G3H.
                                          Should I replace the SMC?
                                          Macbook appears dead with no green light on the charger and no fan spin.
                                          03-20-2023, 03:57 PM
