Hp 840 G3 board no: 6050A2822301-MB-A01 5V, 3V missing
  • mon2
    • Dec 2019
    • 13840
    Re: Hp 840 G3 board no: 6050A2822301-MB-A01 5V, 3V missing
    To determine if Q6010 mosfet is defective, remove all power.
    Meter in resistance mode.
    Measure the resistance across the mosfet pins:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) and drain (5-6-7-8)
    Post all measurements.
    You can test each of the mosfets using the same method. If the resistance readings are low - the mosfet is defective. Best to post every measurement for a review.
    • thema979@yahoo.it
      • Sep 2022
      • 10
      • Italia
      Hi, I can not findd L6035
      Q6010 mosfet measurement:
      source (1-2-3) & drain (5-6-7-8) 1,2 ohm
      source (1-2-3) & gate (4) 189 ohm
      gate (4) and drain (5-6-7-8) 190 ohm
      • mon2
        • Dec 2019
        • 13840
        Can you post a pic of one of these mosfet measurements?
        If indeed in ohms, the readings are extremely low and this part appears to be defective.
        If in ohms on the meter, remove this mosfet -> measure again the same readings but while it is off the logic board and on your work table. This will be the final confirmation that the mosfet is defective and needs to be replaced.
        Proceed to measure the other mosfets that follow this one in the schematic and logic board. Post each measurement.
        reference:
        http://electronicsbeliever.com/how-t...0good%20MOSFET.
        see the resistance method of checking in the above webpage
        • thema979@yahoo.it
          • Sep 2022
          • 10
          • Italia
          mosfet Q6010 is broken, short!
          on board now 120 KOhm
          • mon2
            • Dec 2019
            • 13840
            Ok. So Q6010 will be required to be replaced.
            Proceed to test the other mosfets that follow this one so you can replace each for this repair. Do continue to update this thread.
            • thema979@yahoo.it
              • Sep 2022
              • 10
              • Italia
              #26
              i can't find where to buy MDU1515 anywhere. Only in china but shipping times are long
              • mon2
                • Dec 2019
                • 13840
                The datasheet for the MDU1515 is attached.
                It is a 5x6mm N-channel mosfet.
                Do you have any donor boards?
                Here is the (rough) criteria for a replacement (in order of importance):
                1) Locate a mosfet that is physically this size (5*6)
                2) Must be N-channel
                3) Must be able to support 30V (or higher)
                4) Review the part # of the replacement -> find the datasheet -> check the current that can be supported. Higher the current support, the lower the Rds value and better the part.
                @Piernov has a sticky with more of the finer details on the mosfet selection but start with the above checklist.
                It is very possible that you already have a replacement in your toolbox / donor board(s).
                • thema979@yahoo.it
                  • Sep 2022
                  • 10
                  • Italia
                  #28
                  do you think I can use these ??
                  • mon2
                    • Dec 2019
                    • 13840
                    Yes this looks like a good fit.
                    • thema979@yahoo.it
                      • Sep 2022
                      • 10
                      • Italia
                      #30
                      after changing the mosfet I have no voltage. unfortunately I didn't have time to work on the notebook anymore. Thanks for your help
                      • Chusman14388
                        • Jul 2022
                        • Pakistan
                        #31
                        Originally posted by Sephir0th
                        You're Sure 19V is present at the Current Resistor (See Red circle of attached Pic)?
                        What exactly do you have done in this area?
                        dear if there is no 19v on this resistance than what i will check
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • mferna14
                          Logic Board 820-01987-A missing PP3V3_S5
                          by mferna14
                          Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                          06-07-2025, 05:07 PM
                        • mferna14
                          Logic Board 820-00840-A Missing EDP_BKLT_EN
                          by mferna14
                          Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                          07-10-2024, 05:18 PM
                        • Destroyer-Br
                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                          by Destroyer-Br
                          I'm working on an Acer Nitro 5 unit with the following specs:
                          • Motherboard: LA-J871P Rev: 1B
                          • Model: Acer AN515-55-59MT
                          • S/N: NHQ7JAL00403906A973400
                          • SNID: 03902728734
                          Initial Issue
                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                          04-17-2025, 08:18 PM
