Alienware m14
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Alienware m14
    Hello all, I would like some help, I have a alienware m14, current issue it will not switch on, I've replaced the battery, charger works.
    I need to know on thd battery is a button which when pressed highlights five led lights, when pressed it show the light in full then briefly goes off, can I ask is this showing a fully charged battery or not, I'm nit familiar with this kind of battery.
    I have had the laptop switching on but goes off after brief time, any ideas or anything I can try,
    I've has the battery out, drained out the power by pressing the power button nothing,
  • Sephir0th
    • Oct 2020
    • 1262
    Re: Alienware m14
    1. Share Picture of the Button and the LEDs on the battery you're talking about.
    2. With battery present or shut down after a Short while But doesn't Power on at all with Only charger present?
    Please confirm or explain the issue Better, Like we can Understand what exactly is going on with this Laptop.
    FairRepair on YouTube
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • Simone Vergani
      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
      by Simone Vergani
      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
      To assist with troubleshooting, I'm attaching two power circuit schematics:
      • Power
      03-05-2025, 02:25 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
