O2MICRO just for ref
  • emaghanim
    • 129
    • egypt
    oz 8681l
    oz 8682l
    pinout
  • emaghanim
    • 129
    • egypt
    Re: O2MICRO just for ref
    8682 8681 oz8682 oz8681
    • RichBon
      • Apr 2019
      • 52
      • Ghana
      Originally posted by emaghanim
      oz 8681l
      oz 8682l
      pinout
      sir please what will be the voltage at pin 9
      • mon2
        • Dec 2019
        • 13953
        You can calculate this value using an online resistor based voltage divider.
        However, from the referenced schematic, each resistor is @ 100k ohms so the pin # 9 voltage = 50% of Vin voltage. If it is not ~50% of the Vin voltage, then remove all power and measure the resistance of each of these resistors.
        • RichBon
          • Apr 2019
          • 52
          • Ghana
          sir please which of the resistors should carry the vin voltage. because I am not getting any voltage at PR327
          • mon2
            • Dec 2019
            • 13953
            PR173 resistor is mated with Vin. One side should be the Vin voltage. The other side mates with the next 100k ohm resistor to ground so the voltage @ pin # 9 = 50% of the Vin voltage since both the high side and low side resistors are of the same resistance.
            So even if you had 10k ohm for both of these resistors, pin # 9 = 50% of the Vin. As long as both the high side and low side resistors are the same, pin # 9 will be 50% * Vin.
            • pickledegg
              Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
              by pickledegg
              Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
              I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
              10-02-2024, 04:54 PM
            • maleksa
              Korg Kross2 Service Manual and LCD pinout
              by maleksa
              The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
              However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
              Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
              From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
              10-11-2024, 05:54 AM
            • AlexVG
              SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
              by AlexVG
              I came across with
              SAMSUNG UE65HU8500
              ONE CONNECT BN41-02135
              Chassis GOLF_UHD_1MP_JACK
              TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
              Moreover, on the main is written A5V. However, cable connected this pin to the GND.
              Maybe somebody have an experience with the same issues?
              I need your help.
              Thank you....
              06-08-2025, 06:49 AM
            • Arashiak
              QY6-8002 Canon 2410 2010 inkjet (head pinout) HELPPPP eeprom
              by Arashiak
              Dear all friends
              I am going to read the eeprom inside this printer head i need some help from some expert that work with the canon printers
              1. what chip they use inside the head that i mention in title?
              2. Is there anyone helping me identifying the pinout
              Thanks in advance to all the people that cooperate and Badcaps.net staff.
              05-26-2025, 06:09 PM
            • oldham50
              tcl t-con board 30840-000035 looking for datasheet or ribbon pinout
              by oldham50
              I have a TCL Roku 43" tv that has no picture or sound with vertical lines. I have replaced the main board which solved the no standby voltage problem. I have checked all the voltages on the T-Con board and they are ok. I suspect the VGH voltage is not present on the 2 panel boards but i can not find any marking where this voltage is identified. I am attempting to trace the VGH voltage thru the ribbon cables but need the pinout.
              05-06-2025, 01:40 PM
