A1398 emc2673 820-00426-a disable the discrete
  • skynet85
    • Jul 2015
    • 124
    • Georgia
    Hi all, you have a solution, information on jumpers to disable the discrete on A1398 820-00426-a.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: A1398 emc2673 820-00426-a disable the discrete
    Should work the same as 820-3332.
    https://www.badcaps.net/forum/showpo...47&postcount=3
    • skynet85
      • Jul 2015
      • 124
      • Georgia
      Thanks , i am try this
      • skynet85
        • Jul 2015
        • 124
        • Georgia
        Hello everyone. Initially it turned on, there was a gong, there was no image. I found two solutions to disable the discrete card and transfer to UMA, tried both, now: there is a gong, there is a backlight, there is no image. Was guided by the solution and the diagram from A1398 820-3332 in brackets,
        signals LCD_MUX_SEL LCD_MUX_EN put on GND, L9330 L9410 (L8960 L8930) turned off, and applied 3.3v to LCD_BKLT_EN and LCD_PWR_EN.
        One of the similar topics http://********/viewtopic.php?f=51&t=106005
        Disconnected discrete on these devices. There GMUX is not alone, there is one mikruha that controls everything and the other is just an analog switch! What did you change? I would remove the U9600 microcircuit, then I would turn on the matrix power, the backlight resolution, and so on with five wires. Namely, LCD_MUX_EN -3.3v, LCD_PWR - selection from the built-in, LCD_BKL_EN-selection from the built-in, LCD_MUX_SEL- GND, well, supply 3.3 volts to the PWM backlight, and you turn off the discrete, even the power will not go to it. If the working processor and analog commutator, then you will immediately receive an image on the built-in Intel, if there is no image, check the analog commutator. Sometimes there is an apple and after loading it hangs. In general, I have often come across dependencies on these platforms immediately after loading. The described method immediately cuts off everything except the processor, if problems remain, then we look at the power supply of the processor, and then the percent itself.
        Can you tell me what I'm doing wrong or it doesn't make sense Thank you
        • skynet85
          • Jul 2015
          • 124
          • Georgia
          thank you all very much, I defeated him
          • Sephir0th
            • Oct 2020
            • 1262
            Would you Share the solution, i mean what was wrong before?
            FairRepair on YouTube
            • skynet85
              • Jul 2015
              • 124
              • Georgia
              We also need this solution ?
              • leonemax81
                • Nov 2015
                • 55
                • italia
                skynet 85, then share the solution, I have the same macbook with the same defect, thanks.
                • skynet85
                  • Jul 2015
                  • 124
                  • Georgia
                  I'll post it later
                  • nistel
                    • Aug 2014
                    • 32
                    • Bulgaria
                    Its not too late. It is not fair to not share the solution after all.
                    • moderator
                      • May 2020
                      • 32
                      • India
                      you were suppose to post the solution long back...please do....
                      Thanks in advance
                      • mon2
                        • Dec 2019
                        • 13901
                        There are many that enter the witness protection program after they get the help they need from this forum.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          I completely agree with you Mon, well said.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • moderator
                            • May 2020
                            • 32
                            • India
                            LOL
                            do think that sending private message will help by any chance?!?!
                            • coelectron
                              • Mar 2014
                              • 57
                              • Argentina
                              hello everybody, here the solution that i use in this case, i hope help all
                              Note: for good working is necessary OSX Sierra or older, maybe if you install upper this the machine after sleep show black screen.
                              • Ramu
                                • India
                                • BoozZzy
                                  • Sep 2018
                                  • 8
                                  • ukraine
                                  Ok gays you wont solution.OK)))))
                                  LCD_MUX_EN - 3.3v don't climb, that's how it should be
                                  LCD_MUX_SEL - to GND
                                  LCD_BKLT_EN and LCD_PWR_EN - 3.3v
                                  DP_EXTRA_MUX_SEL_EG - to GND
                                  and GPU_VCORE_EN R8236 - should be deleted
                                  • BoozZzy
                                    • Sep 2018
                                    • 8
                                    • ukraine
                                    PHOTOClick image for larger version
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      you need also one wire to enable backlight once mac goues in sleep mode (like when u close the lcd and reopen it). check that line in the attached picture and adapt on your logic board.
                                      • sachin452
                                        • Sep 2018
                                        • india
                                        can anyone tell me how to solve this issue in a1398 820-00426 after discrete to uma conversion i am facing this issue once it goes in sleep mode the screen remain black kindly help tried conversion with this images below
                                        • dezmiz
                                          MacBook Pro A1398 820-3787-A - Permanently Disable Discrete GPU
                                          by dezmiz
                                          Hello!
                                          I'm trying to permanently disable the dGPU (NVidia GT 750M) in my late-2013 MacBook Pro Retina (A1398 820-3787-A). I can get the system to boot up using the nvram variable "fa4ce28d-b62f-4c99-9cc3-6815686e30f9:gpu-power-prefs=%01%00%00%00", and can prevent the OS from switching to the dGPU via a handful of different methods (e.g. via OpenCore + WhatEverGreen or spoofing the device properties), but the discrete chip seems to stay powered up and cause the machine to overheat. I'm hoping to accomplish something similar to this hardware modification for a 2011 MBP:...
                                          04-01-2021, 06:41 PM
                                        • RotVik
                                          ASUS FX505GT disable discrete GPU
                                          by RotVik
                                          Hello everyone, ASUS FX505GT, dedicated GPU is shorted dead, I would like to disable it completely to activate only integrated CPU graphics.
                                          Any ideas? I was thinking to start by removing L8700 and L8701 so +NVVDD wont power the GPU, and maybe editing BIOS to disable it and also eliminate the possibility of fans going full speed and that kind of weird behavior.
                                          Is this possible? Any help would be great!
                                          Schematic & Boardview
                                          https://www.badcaps.net/forum/troubl...ets-and-mobile...
                                          05-15-2025, 05:19 PM
                                        • brotank
                                          Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                                          by brotank
                                          I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                                          can someone disable onboard ram from my dumped bios, please 🙏
                                          I tried the other bios on this forum with disabled onboard ram, but no success
                                          my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                                          after that I officially give up 😂
                                          thanks for awesome jobs 😊...
                                          03-16-2025, 12:51 PM
                                        • reset1986
                                          macbook a1398 820-3332a bios gpu disable
                                          by reset1986
                                          hi, i have problems with nvidia gpu, it has been removed
                                          R8999 -> PPVCORE_S0_GFX_PH1
                                          R8998 -> PPVCORE_S0_GFX_PH2
                                          jumpered R9404 with c9711 for fixed lighting, I would need a dump with gpu disabled, the bios chip is new and I flashed a dump found on the net, I hear the boing but I get black screen, can someone post a dump with gpu disabled? thanks
                                          820-3332a emc 2512
                                          11-13-2022, 01:52 PM
                                        • Fam787
                                          HELP! A1398 Dead,
                                          by Fam787
                                          I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
                                          Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
                                          12-27-2024, 05:19 PM
