LA-C421P BQ24780S no ACDRV
    • 21874
    Re: LA-C421P BQ24780S no ACDRV
    Originally posted by janpatirkckaram1992
    did you just solder the 1st fet drain to source?
    read it again,the problem is SW1 ,do not bypass the mosfet.
    • coltron
      • Jan 2021
      • 98
      • England
      Just trawling my old laptop diagnosing posts and seen added posts since original board view request..i lost interest in the board after a couple of months of unsuccessful attempts.
      one day i may dig out the L560 board and try the sw 1 top pins bridge only suggestion by rbvdon..
      board won't be worth much even if fixed, but hey, sometimes its about the challenge.
      smd Flea, thanks for comment regarding mosfet bypass, At the time I watching to many early you tube videos (Sorin) showing mosfet bridging as a solution.
      I now understand the dangers of inducing a false start scenario.
      • hamza hamza
        • May 2022
        • 31
        • morocco
        thanks
        • jackx
          • May 2020
          • 222
          • casa1
          hello when tape ws1 laptop power on not data heat u401 3v 5v ic
          • menshawy
            • Aug 2013
            • 400
            • egypt
            The LA-C422P has a similar layout. https://www.badcaps.net/forum/showthread.php?t=88885 .I read on one forum that SW1 was broken causing a problem.Tape it down,if the switch is working ok and check CMSRC and ACDRV again.
            thanks boss
            • BlackScreen_22
              Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
              by BlackScreen_22
              Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
              Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
              I had no problems connecting mosfets and capacitors,...
              08-27-2024, 12:46 PM
            • kotel studios
              Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
              by kotel studios
              Finally got time to fix this board up.
              At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
              Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
              04-22-2025, 05:08 AM
            • flerre
              Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
              by flerre
              Hi!
              Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
              No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
              So, could I safely assume all of these 3 mosfets are...
              03-13-2022, 12:14 PM
            • DrDos
              kenwood kr-6030 Mosfets?????
              by DrDos
              Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
              09-20-2025, 04:42 PM
            • Thomas Smith
              Asus Tuf gaming fx506l no power, mosfet does not open
              by Thomas Smith
              Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
              Initial Symptoms:
              • The laptop has no power at all (no LEDs, no fan spin).
              • No 3.3V or 5V present on the board.
              • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
              Power Rail Checks:
              1. Charger input (FETs PKCH2BB)
                • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
              2. BQ24780S Charger IC:
                • VCC and ACDET are present.
                • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                • Shunt resistor has 10Ω to ground.
              03-30-2025, 03:38 AM
