La-c881p
  • riki_22
    • Jun 2014
    • 63
    • italia
    La-c881p
    Hello everybody,
    problem on xps 13 9350 with battery turns on but does not recharge and only with power supply does not turn on.
    i found pd300 burnt.
    because I found the broken connector with the pins that made contact. Removed PD300 E
    fixed the connector
    but i can't solve
    Please help me
    P.S. for me it is a power supply control circuit problem
  • riki_22
    • Jun 2014
    • 63
    • italia
    Re: La-c881p
    I am attaching photos
    • Sephir0th
      • Oct 2020
      • 1262
      Re: La-c881p
      This is of course an issue around the charging controller.
      But you replaced PD300 with the correct part, right? Confirm this first!
      Then continue with Voltage measurements at PR300 and PR313 with only Adapter present. Sahre the values. Also check PU300, Pin5 and Pin6 voltage?
      FairRepair on YouTube
      • riki_22
        • Jun 2014
        • 63
        • italia
        Re: La-c881p
        I don't have a double diode to put on the PD300, but if I don't insert the battery nothing really should happen. I still made the measurements PR313 3.2V
        PR300 19.6V
        PU300 P5 3.2V and P6 2.8V
        can you advise me where to get a pd300 i have many donor motherboards
        • Sephir0th
          • Oct 2020
          • 1262
          Re: La-c881p
          Measurements of PU300 and PR300 are fine. PR313 too Low (from charger).
          It is still working from Battery?
          Regarding the replacement, i can't Take Over the job to search for it for you. Compare with datasheets or Just Order a new one. I'm Not 100% Sure about the function of PD300 in the Circuit but could be important and ofc missing could prevent the Board from booting with Adapter.
          • riki_22
            • Jun 2014
            • 63
            • italia
            Re: La-c881p
            With the battery it works.
            With the power supply does not turn on and does not recharge, can this be due to the lack of pd302?
            and in your opinion pr313 is low because pd302 is missing?
            I found CH501H-40PT I can change it with SDMK0340L
            • Sephir0th
              • Oct 2020
              • 1262
              Re: La-c881p
              This is NVDC Design, and tbh i'm Not so experienced there in Detail, and i wouldn't Try to Power on the Board before replacing PD300, so yes could be.
              Also checked PQ303 and PQ304 for internal Short Circuit? Gate voltages of both Mosfets? PR313 Voltage with Only Battery present?
              Edit: i believe without this diode PU300 will Not receive Power at Pin 28 in battery Mode. Confirm pls. And Check Pin28 with Only Adapter present too.
              • riki_22
                • Jun 2014
                • 63
                • italia
                Re: La-c881p
                PQ303 and PQ304 are not internally shorted, the gate of PQ303 is 3.6V and of pq304 is 0.36V
                in the PR313 with battery the voltage is 7.73V
                PIN28 of PU300 with only adapter is 19.6 , with only battery is 7.15v and both 19.6v but it goes out immediately with both. only battery WORK
                • mon2
                  • Dec 2019
                  • 13898
                  Re: La-c881p
                  Do you have the schematics for this logic board? Please post them if you do.
                  Otherwise, what is the battery charger IC on the board?
                  • riki_22
                    • Jun 2014
                    • 63
                    • italia
                    Re: La-c881p
                    can i change pd300 (SDMK0340L) with RB501V-40?
                    • riki_22
                      • Jun 2014
                      • 63
                      • italia
                      Re: La-c881p
                      attached the pdf of schematic. the ic is BQ24777
                      • Sephir0th
                        • Oct 2020
                        • 1262
                        Re: La-c881p
                        Just added the Schematics in the Schematics section. I Only was a few Seconds to slow...
                        • Sephir0th
                          • Oct 2020
                          • 1262
                          Re: La-c881p
                          Do you have jumpered PD300 Pads?
                          • riki_22
                            • Jun 2014
                            • 63
                            • italia
                            Re: La-c881p
                            Originally posted by sephir0th
                            do you have jumpered pd300 pads?
                            no try?
                            • Sephir0th
                              • Oct 2020
                              • 1262
                              Re: La-c881p
                              No, i Just Wonder how it is possible that the battery Voltage Receives Pin28. Something seems to be wrong. Either we're working on the wrong component or Schematics don't fit.
                              • riki_22
                                • Jun 2014
                                • 63
                                • italia
                                Re: La-c881p
                                it may be that the scheme is a different revision but the problem for me is
                                missing pd300
                                • Sephir0th
                                  • Oct 2020
                                  • 1262
                                  Re: La-c881p
                                  Voltages of PQ303 D - G - S when Only Adapter and Only Battery is present?
                                  • mon2
                                    • Dec 2019
                                    • 13898
                                    Re: La-c881p
                                    Remove battery. Connect adapter.
                                    1) voltage on pin 6 (acdet; pu300) ?
                                    2) voltage on pin 17 (pu300) ?
                                    3) voltage on pin 1, pl300? Pin 2, pl300?
                                    4) pl301, pin 1? Pin 2?
                                    5) confirm the nearby diodes are ok (power removed, meter in diode mode). Should conduct in one direction, block in the other).
                                    6) pin 15 voltage of pu300 with adapter only?
                                    • riki_22
                                      • Jun 2014
                                      • 63
                                      • italia
                                      Re: La-c881p
                                      Only Adapter in PQ303 D 19.6V S 3.2V G 3.6V
                                      Only Battery in PQ303 D 7.06V S 7.44V G 7.33V
                                      • piernov
                                        • Jan 2016
                                        • 4435
                                        • France
                                        Re: La-c881p
                                        Voltage from battery goes through PQ305 & PQ303 body diode to reach VCC pin of charger IC.
                                        PD300 should be replaced first, not much point troubleshooting further if parts are missing.
                                        You need a Schottky diode of at least 30V reverse voltage and 30mA forward current and the same package. So yes RB501V-40 should be good instead of SDMK0340L
                                        Note that it's possible there is a secondary problem and PD300 will burn again, so keep a few aside in case. It's also possible it's the only problem and replacing it will solve it.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • hillbillybubba
                                          XPS 13 9360 - Is it possible to directly charge the battery, at the connector, with adjustable power supply?
                                          by hillbillybubba
                                          I see the positive and negative wires on the connector, but will it even allow a charge without the other connectors doing whatever communication it is that they do?
                                          I'm well-versed in battery charging, just not laptop batteries. (I'm a lithium battery reseller)
                                          Laptop became unresponsive while in storage, battery was in great health the last time I cut it off, but now it's reading zero volts at the connector.
                                          01-24-2025, 11:01 AM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                          DELL XPS 9350 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9350 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9350 boardview and 9350 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9350 Notebook...
                                          09-06-2024, 07:11 AM
