No BackLight Asus X455LJ rev 3.1
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi good day I have a shorted backlight capacitor but I dont know if its a capacitor or a rresistor because it was blown. Hoping someone can give advice
    Ill attached the brd.
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Re: No BackLight Asus X455LJ rev 3.1
    Can I just jumper it?
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      exploding component no?
      I'm not happy to be so strong. because it's not humanly
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        l6407
        • megateknik33
          • Dec 2020
          • türkiye
          hello did you check the fuses?
          • mon2
            • Dec 2019
            • 14720
            In your picture, the tantalum cap with 330 markings, us it damaged? Looks that way in the photo. Can you show another close up of that part?
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              • Sametbey
                • Jan 2021
                • 229
                • Turkey
                L4607 coil LVDS + B provider appears in your boardview file. You can use 2.2ohm 1 / 2w resistance or low omage coil.
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  what happens if I just jumper it sie?
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    A short circuit in the panel or LVDS cable can damage the motherboard
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      Thanks sir , It was just like a fuse maybe?
                      • ktmmotocross
                        Asus G513QE keyboard and backlight not working
                        by ktmmotocross
                        Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                        i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                        but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                        08-08-2025, 06:29 AM
                      • user546087
                        Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                        by user546087
                        I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                        - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                        - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                        - try to find out, how it is done, look at schematics - this is, where we are at.
                        - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                        02-24-2025, 02:03 AM
                      • FallenOne008
                        Asus G712L No Screen Backlight
                        by FallenOne008
                        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                        03-31-2025, 08:27 PM
                      • hardwareserwis
                        Asus Strix G513QR logo appears, then only the backlight stays on
                        by hardwareserwis
                        Asus Strix G513QR-HF016
                        Motherboard: G533-MP-GBM, 6050A3250202-MB-A01
                        The motherboard powers on, the Strix logo appears, then only the backlight stays on — it does not enter the BIOS and hangs at that stage.
                        The laptop arrived with a broken screen and a damaged display cable.
                        Actions performed:
                        • New BIOS dumps have been flashed
                        • A new Ryzen 7 CPU was soldered in (tested with two different units), but the issue remains the same with both
                        • Tested with a different display cable and screen
                        • No missing components or visible damage on the motherboard; no components
                        09-29-2025, 01:02 PM
                      • obdcart
                        Asus X415ea Adding a Keyboard with Backlight
                        by obdcart
                        Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                        I hope you can give me some help
                        06-28-2024, 02:21 PM
