Dell N5010 display issue after UMA conversion
+ More Options
Posts
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, need help figuring out what's causing the following issue.
    I have a dell N5010 which had a bad GPU chip and a UMA conversion was performed.
    Initial conversion was done per this video: https://www.youtube.com/watch?v=cq8r920tW64
    After conversion, laptop boots and display comes on but once windows starts loading, it becomes all fuzzy/dotted. I initially though it could be a driver issue, so I removed the HDD and booted into BIOS settings. Image was not fuzzy but some letter jitters (like dancing dots at the edge of the letters) was visible. I tried to boot from windows installation disk (without HDD plugged in)but still has same fuzzy image (see attached picture).
    I removed the VRAMs and followed the "new conversion guide" (as attached) but image still remains same.
    Tests done(with no change):
    1. Laptop display is known good
    2. Tried known good RAM
    3. Tried known good CPU
    4. Check proper 25MHz signal on PCH with DSO - (25MHz and stable)
    5. Replaced load capacitor for 25MHz crystal
    6. Replaced load Resistor for 25MHz crystal
    7. Recheck if I did not miss any components removal, shifting and/or adding as per guide
    8. Check solder joints of parts shifted/added
    9. Check if parts shifted/added have proper values and haven't been damaged
    10. Check stable voltage levels from different regulators
    11. Check if there was no shorting of solder from removed parts.
    Other Observations:
    1. Dots do not appear if I open Command Prompt in windows install.
    2. Some Dots can be observed around (especially bottom edge) windows logo while OS is loading
    3. No dots at all when prompted to choose 32 or 64bits when installing windows
    4. When booted into windows (installed on HDD), laptop is very slow and takes a while to register mouse key press and opening folders. Mouse pointer moves smoothly though.
    At this point am not sure what else to test and starting to think I may have a bad PCH? Any suggestions is greatly appreciated.
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: Dell N5010 display issue after UMA conversion
    clean and try the lvds socket on the panel. Start panel test mode by pressing the start button together with the D button.
    I'm not happy to be so strong. because it's not humanly
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Hi Sametbey, cleaning the LVDS connectors did not help, I still get dotted image.
      Panel test actually passes without issues and colors are good too. No dots can be seen during test.
      When windows is loaded from HDD, laptop is painfully slow. Any other suggestion?
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        I also noticed that external display is not working (not even being detected). Neither on HDMI nor on VGA.
        • laptopzoneakl
          • Dec 2021
          • 3
          • India
          dell 5010 7 beeps after conversion
          • kingkai933
            • Jul 2023
            • Cairo
            he video is no longer available. Is it possible for you to re-upload the video on YouTube again?
            • ruknet
              • Dec 2020
              • 5
              • TΓΌrkiye
              Other Observations:
              Hello, I have the same problem after converting to uma. Were you able to solve this problem?​
              • sew333
                Please help, I have an issue with new monitor Aorus FI27Q (black dots dropping down v
                by sew333
                Hello.
                First my pc.I have Gigabyte Rtx 3090 OC ( stock ) and 10850K stock ,32gb ram.
                Issue is only on 1920x1080P with 165hz. On 1440P with 165mhz is fine. On 1920x1080P with 144hz is fine. On 1920x1080P with 165mhz i can see on screen small black dots flickering vertical.
                If i wanna catch screen its not visible or clip. So i post screen and i added from paint. Just very small flickering black dots on vertical position. Screens not working. Happens only in 1080P with 165HZ. Visible on desktop too when i am very close.
                Just found on reddit somebody had the same...
                03-10-2021, 05:13 PM
              • pratyush
                N5010 colour issue after conversion
                by pratyush
                Facing orange colour issue on screen after conversion discrete to uma..what will be possible solution.....
                02-02-2019, 06:20 AM
              • pc1staid
                Dell Latitude E7270 shut down issue
                by pc1staid
                Hi Guys and Gals,
                I have a really strange issue with the above titled Ultrabook.
                Quick spec's, i7-6600 with intel HD520 graphics, 8GB DDR-4 RAM, 256GB M.2 SSD, 12" screen, Wifi, Finger print, NFC.
                Use of the laptop is out on sites, remoted into a NAS just for files, software installed Win10, Office 2019, Teams, Printer software. Thats it, sledge hammer to crack a walnut.
                OK, the issue. 4 days prior to me getting it, just after login, approx 15 secs the laptop will shutdown. Not as in power off/cut, no restart, it goes through the shut down procedure. This is...
                12-19-2020, 01:17 AM
              • SuperJames
                Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                by SuperJames
                This one's a weird one, and still unsolved despite it having gone back to Dell once.
                Specs
                i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                Backstory
                I bought this from eBay, from a wallpapering shop. Β£650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                10-23-2023, 04:09 PM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
