Asus UX303UB charging problem green led blinking
  • Fernon@Repair
    • Jan 2021
    • 20
    • Sri Lanka
    Re: Asus UX303UB charging problem green led blinking
    ac ok showing 6v.... no power no lied showing solution pls asus x409aj
    • mon2
      • 13829
      For this application, the ACOK is pulled up by a resistor to REGN. So we know REGN is a good value of 6V.
      This voltage value is used to boost the voltage on the ACDRV pin.
      What is the voltage on the ACDRV pin?
      After this check, remove all power. Then locate and remove the external resistor (~4k ohms) that will be in series with the ACDRV pin on the charger IC).
      After this resistor is removed, what is the voltage of ACDRV pin? If all is ok, it should be ~25 volts = adapter input voltage + REGN voltage.
      Confirm it.
      • canali
        • Oct 2014
        • 188
        • turkey
        thanks
        • mon2
          • 13829
          With a 19v power adapter as the source, the voltage on pin #28 (VCC) is too low.
          There should be a dual common cathode diode to feed power from the adapter or battery. Check the voltage on each pin of this dual diode. If still the voltage you posted, replace it.
          Also with no power, check the resistance to ground of this VCC pin. Something is wrong here to drop almost 3 volts.
          • jxrepman
            Asus X453MA won't turn on and green led light blinking
            by jxrepman
            Hi there,
            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
            I have checked the charger and it is giving 19+ V
            I have disconnected the battery and pressed power button for 30 seconds.
            I tried another RAM stick.
            Tried disconnecting the keyboard and touchpad.
            Tried disconnecting the HDD and the wifi adapter.
            The problem persists.
            Hope you could help me out on this one. Thank you.
            12-14-2024, 06:40 AM
          • 1centchips
            Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
            by 1centchips
            I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
            The laptop is just out of warranty.
            The laptop continues to freeze randomly with the blinking amber charging light.
            What could be possibly wrong with it?
            I have also disable armoury crate in bios.
            12-17-2024, 05:18 PM
          • binary0101
            Asus X453SA No Display - Charging Indicator Blinking
            by binary0101
            Greetings
            I got an Asus X453SA for repair
            Symptom : no display, with charging indicator blinking, with or without battery. Power indicator is steady. When battery plugged in, the current consumption jumps, but the charging indicator is still blinking.
            Here is the measured power sequence :
            +3VA_EC +3.3V
            EC_RST# +3.025V
            +5VSUS_ON +3.307V
            PWR_SW# +2.982V
            3VSUS_ON +3.307V
            SUS_PWRGD +3.386V
            +1.05VSUS_PWRGD +1.061V
            1.8VSUS_EN +1.873V
            VSUS_PWRGD +3.383V
            PM_PWRBTN# +1.830V
            PM_RSMRST#...
            02-01-2023, 02:33 PM
          • johnbeton
            Asus X415EA not charging battery
            by johnbeton
            I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
            So far I measured all the pins on the bq24780s controller with the following result:
            1. ACN = 0.0V
            2. ACP = 19.02V
            3. CMSRC = 18.5V
            4. ACDRV = 23.9V
            5. ACOK = 5.9V
            6. ACDET = 2.57V
            7. IADP = 0.17V
            8. IDCHG = 0V
            9. PMON = ?
            10. PROCHOT = 5.05V
            11. SDA = 3.3V
            12. SCL = 3.3V
            13. CMPIN = 0.47V
            14. CMPOUT = 6.0V
            15. BATPRES = 0.0V
            16....
            05-19-2025, 04:05 AM
          • shahnld
            Sony kdl 65xg9505 green amber blinking
            by shahnld
            Good Day.
            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
            01-03-2024, 03:05 PM
